Date/Time: Fri, 28 Feb 2025 13:28:21 +0000
Error MaxConnectionsDifferentDevice = 1 using SC Historical Equities
View Count: 555
[2021-08-24 12:48:54]
DabbaDo - Posts: 148
I'm on Package 5 running US Equities realtime SC Data - All Services.
Version 2296
I'm getting:
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-08-24 08:40:53.250
Shouldn't I be able to use a 2nd machine on package 5 with US Equities? Is there a setting that I'm missing?
Thank you,
Dale
[2021-08-24 18:17:39]
John - SC Support - Posts: 38259
No. The Sierra Chart Exchange Data Feed only allows for one connection at a time. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Connections
