Date/Time: Fri, 28 Feb 2025 18:18:13 +0000
how to copy all studies in a chart to a new blank chart?
View Count: 486
[2021-08-23 12:46:09] |
User427561 - Posts: 217 |
I can save all studies of the original chart, do not know how to retrieve that saved group to copy paste in he new chart, thanks
[2021-08-23 12:54:14] |
User907968 - Posts: 833 |
It is explained in details here - Study Collections You can find your saved study collections in the 'Analysis' menu. |
[2021-08-29 13:46:17] |
You need to use Study Collections as explained. Full documentation is here: Study Collections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
