Date/Time: Fri, 28 Feb 2025 13:44:17 +0000
Unable to connect Rithmic direct DTC with 2299
View Count: 787
[2021-08-22 22:48:00] |
Kza57 - Posts: 13 |
Hello, Just update to 2299 and I'm unable to connect to Rithmic direct DTC. All works fine with 2292,but not with 2296 and 2299. Below the message log... thx Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-08-23 00:47:10.848 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-08-23 00:47:10.853 DTC Client socket (6) | Creating socket. Using TLS 1.2. | 2021-08-23 00:47:10.854 DTC Client socket (6) | New receive buffer size: 5242880 | 2021-08-23 00:47:10.854 DTC Client socket (6) | Connecting to IP: 216.57.156.163. | 2021-08-23 00:47:10.854 Rithmic Direct - DTC | Network connection to server complete. | 2021-08-23 00:47:11.014 Rithmic Direct - DTC | Starting socket receive thread. | 2021-08-23 00:47:11.014 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-08-23 00:47:11.014 Rithmic Direct - DTC | Sending logon request message. | 2021-08-23 00:47:11.014 DTC Client socket (6) | Socket gracefully closed by remote side. | 2021-08-23 00:47:11.363 DTC Client socket (6) | CloseSocket call. | 2021-08-23 00:47:11.395 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-08-23 00:47:11.395 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-08-23 00:47:11.395 DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 00:47:11.395 DTC Client socket (6) | Closed. | 2021-08-23 00:47:11.395 WSACleanup called. | 2021-08-23 00:47:11.451 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-08-23 00:47:11.451 DTC Client socket (0) | CloseSocket call. | 2021-08-23 00:47:11.451 Rithmic Direct - DTC | Disconnected. | 2021-08-23 00:47:11.451 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-08-23 00:47:11.451 |
[2021-08-22 23:22:20] |
fcpauldiaz - Posts: 18 |
I'm having the same issue
[2021-08-23 04:42:21] |
Must be a Rithmic Server issue.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-23 04:42:27
[2021-08-23 07:18:43] |
Kza57 - Posts: 13 |
I'm not sure. Just testing now, It doesn't work with 2299. I downgrade to 2292 and it works. Look at the time on the logs : 2299 : Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-08-23 09:11:04.889 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-08-23 09:11:04.895 DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2021-08-23 09:11:04.896 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-08-23 09:11:04.896 DTC Client socket (4) | Connecting to IP: 216.57.156.163. | 2021-08-23 09:11:04.896 Rithmic Direct - DTC | Network connection to server complete. | 2021-08-23 09:11:05.012 Rithmic Direct - DTC | Starting socket receive thread. | 2021-08-23 09:11:05.012 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-08-23 09:11:05.012 Rithmic Direct - DTC | Sending logon request message. | 2021-08-23 09:11:05.012 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-08-23 09:11:05.357 DTC Client socket (4) | CloseSocket call. | 2021-08-23 09:11:05.385 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:11:05.385 DTC Client socket (4) | Closed. | 2021-08-23 09:11:05.385 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-08-23 09:11:05.386 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-08-23 09:11:05.386 WSACleanup called. | 2021-08-23 09:11:05.454 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-08-23 09:11:05.454 DTC Client socket (0) | CloseSocket call. | 2021-08-23 09:11:05.454 Rithmic Direct - DTC | Disconnected. | 2021-08-23 09:11:05.455 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-08-23 09:11:05.455 2292 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2021-08-23 09:13:48.715 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 32768 | 2021-08-23 09:13:48.715 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. | 2021-08-23 09:13:48.715 Created the DTC Protocol server. | 2021-08-23 09:13:48.755 DTC Protocol Server listening on port 11099. | 2021-08-23 09:13:48.757 Reading Internal Order ID file. | 2021-08-23 09:13:48.757 Reading Trade Orders file. | 2021-08-23 09:13:48.869 Reading Trade Positions file. | 2021-08-23 09:13:48.870 Reading Trade Account Data files. | 2021-08-23 09:13:48.870 UDPListener (1524). Port 22904 | Listening on UDP port 22904. | 2021-08-23 09:13:48.892 Software version: 2292 64-bit | 2021-08-23 09:13:48.892 Primary Thread ID: 13864 | 2021-08-23 09:13:48.892 Usage end date: 2021-09-05 | 2021-08-23 09:13:48.892 Enabled for: Advanced Features 2. | 2021-08-23 09:13:48.892 Enabled for: Sierra Chart Historical Data Service. | 2021-08-23 09:13:48.892 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-08-23 09:13:48.892 Enabled for: Delayed Denali Exchange Data Feed. | 2021-08-23 09:13:48.892 Enabled for exchange2: CME | 2021-08-23 09:13:48.892 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-08-23 09:13:48.892 Current selected Data/Trading service: Rithmic Direct - DTC | 2021-08-23 09:13:48.892 Custom symbol settings values: enabled | 2021-08-23 09:13:48.892 Chart Update Interval: 100 | 2021-08-23 09:13:48.892 Intraday Data Storage Time Unit: 0 | 2021-08-23 09:13:48.892 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2021-08-23 09:13:48.892 2021-08-23 07:13:48 Local computer time in UTC | 2021-08-23 09:13:48.892 2021-08-23 09:13:48 Local computer time in SC Time Zone | 2021-08-23 09:13:48.892 2021-08-23 07:13:47 Server time in UTC | 2021-08-23 09:13:48.892 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-08-23 09:13:48.892 Program path: C:\SierraChart\ | 2021-08-23 09:13:48.892 Data Files path: C:\SierraChart\Data\ | 2021-08-23 09:13:48.892 OS Version Number: 10.0 | 2021-08-23 09:13:48.893 Locale Setting: C | 2021-08-23 09:13:48.893 DLLs: DeltaPivotPoints_64.dll, Display Study as Numbers on Bottom v3.dll, ExtractQuantData.dll, IcebergAskDetector_64.dll, IcebergBidDetector_64.dll, OrderFlowLabs.com.bod_64.dll, OrderFlowLabs.com_64.dll, QuantDepthV1.0.dll, QuantLevelsV1.0.dll, QuantMapV1.0.dll, QuantSpeedV1.0.dll, sst_draw_imbalance_64.dll, sst_FreeBundle_64.dll, sst_request_bundle_64.dll, tradeinpool.dll, tradingpoolV4_64.dll, TWFX_FREE_2151_64.dll, UserContributedStudies_64.dll, WMOv4.dll, WMOv4_64.dll, zyp sierra free 2020_2151_64.dll | 2021-08-23 09:13:48.893 Allowed protected custom studies: Display Study as Numbers on Bottom, OrderFlowLabs.com, Quant Depth V1.0, Quant Levels V1.0, Quant Map V1.0, Quant Speed V1.0, SST_DrawImbalanceLevels, SST_FreeBundle, SST_RequestBundle, TWFX_Free, Wem's Orderflow, Wem's Orderflow Analysis, zyp_download_free | 2021-08-23 09:13:48.893 Created the DTC Protocol historical data server. | 2021-08-23 09:13:48.915 HD Server Manager | Listening on port 11098. | 2021-08-23 09:13:48.917 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. | 2021-08-23 09:13:48.917 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-08-23 09:13:48.935 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-08-23 09:13:48.983 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-08-23 09:13:48.983 Received 5 login tokens. | 2021-08-23 09:13:49.077 Symbol settings MD5 received. Request ID: 1. | 2021-08-23 09:13:49.219 Requested symbol settings for service code rithmic_v2.trading. Request ID: 2. | 2021-08-23 09:13:49.219 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2021-08-23 09:13:49.256 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. | 2021-08-23 09:13:49.256 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:13:49.256 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. | 2021-08-23 09:13:49.256 Symbol settings received. Request ID: 2. | 2021-08-23 09:13:49.610 Files to Open on Startup | Opening file: ES FOOTPRINT.Cht | 2021-08-23 09:13:53.279 Loading DLL: C:\SierraChart\Data\zyp sierra free 2021.dll (zyp sierra free 2021_2151_64.dll). Handle: 7ff9f16e0000 | 2021-08-23 09:13:53.292 Loading DLL: C:\SierraChart\Data\TWFX_FREE.dll (TWFX_FREE_2151_64.dll). Handle: 7ff9f1650000 | 2021-08-23 09:13:53.297 Loading DLL: C:\SierraChart\Data\sst_draw_imbalance.dll (sst_draw_imbalance_64.dll). Handle: 66000000 | 2021-08-23 09:13:53.300 Chart (ESU1.CME) | Encountered unknown Chartbook Field. Field Code: 598. Previous Field Code: 164 | 2021-08-23 09:13:53.305 Chart (ESU1.CME) | Encountered unknown Chartbook Field. Field Code: 597. Previous Field Code: 596 | 2021-08-23 09:13:53.305 ESU1.CME [CV] Rev. 4t #1 | Reloading chart. | 2021-08-23 09:13:53.359 ESU1.CME [CV] Rev. 4t #1 | Performing historical Daily data download for symbol ESU1.CME starting at last date in file. | 2021-08-23 09:13:53.364 Starting DelayedDownloadMonitoringTimer | 2021-08-23 09:13:53.364 Starting HDTimeoutTimer | 2021-08-23 09:13:53.364 Added historical Daily data request for ESU1.CME to the queue. | 2021-08-23 09:13:53.364 Triggering next historical data download in queue. | 2021-08-23 09:13:53.364 ESU1.CME [CV] Rev. 4t #1 | File ESU1.CME.dly has a volume of 0 at 2021-08-23. | 2021-08-23 09:13:53.387 ESU1.CME [CV] Rev. 4t #1 | Waiting for historical downloads to complete with the IDs: 1, | 2021-08-23 09:13:53.387 Chart (ESU1.CME) | Encountered unknown Chartbook Field. Field Code: 598. Previous Field Code: 164 | 2021-08-23 09:13:53.419 Chart (ESU1.CME) | Encountered unknown Chartbook Field. Field Code: 597. Previous Field Code: 596 | 2021-08-23 09:13:53.419 ESU1.CME 10000 Volume #3 | Reloading chart. | 2021-08-23 09:13:53.445 Chart (ESU1.CME) | Encountered unknown Chartbook Field. Field Code: 598. Previous Field Code: 164 | 2021-08-23 09:13:53.453 Chart (ESU1.CME) | Encountered unknown Chartbook Field. Field Code: 597. Previous Field Code: 596 | 2021-08-23 09:13:53.453 ESU1.CME [C] Point & Figure 10-1 #6 | Reloading chart. | 2021-08-23 09:13:53.477 Chart (NQU1.CME) | Encountered unknown Chartbook Field. Field Code: 598. Previous Field Code: 164 | 2021-08-23 09:13:53.489 Chart (NQU1.CME) | Encountered unknown Chartbook Field. Field Code: 597. Previous Field Code: 596 | 2021-08-23 09:13:53.489 NQU1.CME [CV] Rev. 16t #4 | Reloading chart. | 2021-08-23 09:13:53.522 NQU1.CME [CV] Rev. 16t #4 | Performing historical Daily data download for symbol NQU1.CME starting at last date in file. | 2021-08-23 09:13:53.524 Added historical Daily data request for NQU1.CME to the queue. | 2021-08-23 09:13:53.524 NQU1.CME [CV] Rev. 16t #4 | File NQU1.CME.dly has a volume of 0 at 2021-08-23. | 2021-08-23 09:13:53.541 NQU1.CME [CV] Rev. 16t #4 | Waiting for historical downloads to complete with the IDs: 2, | 2021-08-23 09:13:53.541 Mapping ESU1.CME to ESU21. Service code: cme | 2021-08-23 09:13:53.557 HD Request # 1 | Downloading Historical Daily chart data for ESU1.CME. Starting date: 2021-08-19. Service: rithmic.trading | 2021-08-23 09:13:53.559 Starting DelayedDownloadMonitoringTimer | 2021-08-23 09:13:53.574 Starting HDTimeoutTimer | 2021-08-23 09:13:53.574 Added historical Intraday data request for ESU1.CME to the queue. | 2021-08-23 09:13:53.574 Intraday data recording state for symbol ESU1.CME is set to download 'Pending'. | 2021-08-23 09:13:53.574 Triggering next historical data download in queue. | 2021-08-23 09:13:53.574 HD Request # 2 | Downloading Intraday chart data for ESU1.CME to the file ESU1.CME.scid. Service: cme | 2021-08-23 09:13:53.575 HD Request # 2 | Download start date-time: 2021-08-23 09:10:31.000000. File last date-time: 2021-08-23 09:10:31.007007 | 2021-08-23 09:13:53.575 HD Request # 2 | Using server: ds23.sierracharts.com port 10150 | 2021-08-23 09:13:53.575 Socket (2) | Creating socket. | 2021-08-23 09:13:53.576 Socket (2) | New receive buffer size: 5242880 | 2021-08-23 09:13:53.576 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-08-23 09:13:53.576 HD Request # 2 | Setting DTC encoding to Binary VLS | 2021-08-23 09:13:53.808 HD Request # 2 | Sending historical data logon request message. | 2021-08-23 09:13:53.808 HD Request # 1 | Requesting historical Daily data for ESU21 starting at 2021-08-18. SC External HD service. | 2021-08-23 09:13:53.841 HD Request # 2 | Requesting Intraday data. Start date-time: 2021-08-23 09:10:31. Record interval: 0. Symbol: ESU21 | 2021-08-23 09:13:54.375 HD Request # 2 | Decompressing data. | 2021-08-23 09:13:54.485 HD Request # 2 | Receiving Intraday data for ESU1.CME starting at 2021-08-23 09:10:31.005000 | 2021-08-23 09:13:54.487 Socket (2) | CloseSocket call. | 2021-08-23 09:13:54.488 HD Request # 2 | Historical data for ESU1.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2021-08-23 09:13:54.488 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-08-23 09:13:54.488 Historical data download thread signaled to stop. | 2021-08-23 09:13:54.488 HD Request # 2 | Timestamp of first Intraday data file record written: 2021-08-23 09:10:35.177000 | 2021-08-23 09:13:54.488 HD Request # 2 | Received 664 Intraday data records from 2021-08-23 09:10:31.005000 to 2021-08-23 09:13:50.412004 (3.3 minutes) and wrote 640 records for ESU1.CME | 2021-08-23 09:13:54.488 HD Request # 2 | Completion time: 1s | 2021-08-23 09:13:54.488 HD Request # 2 | Intraday data download complete for ESU1.CME. Unique request ID: 3 | 2021-08-23 09:13:54.488 Removing historical data download ID 3. | 2021-08-23 09:13:54.488 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2021-08-23 09:13:54.488 Triggering next historical data download in queue. | 2021-08-23 09:13:54.488 No download requests in the queue to start downloads for. | 2021-08-23 09:13:54.488 Socket (2) | Socket gracefully closed by remote side. | 2021-08-23 09:13:54.598 Socket (2) | Closed. | 2021-08-23 09:13:54.598 HD Request # 1 | Receiving historical Daily data for ESU1.CME starting at 2021-08-19 | 2021-08-23 09:13:54.600 HD Request # 1 | Writing historical Daily data to the file ESU1.CME.dly | 2021-08-23 09:13:54.600 HD Request # 1 | Bytes received: 232 | 2021-08-23 09:13:54.604 HD Request # 1 | Received 4 Daily data records from 2021-08-19 00:00:00 to 2021-08-23 00:00:00 (5.0 days) and wrote 3 records for ESU1.CME | 2021-08-23 09:13:54.604 HD Request # 1 | Completion time: 1s | 2021-08-23 09:13:54.604 HD Request # 1 | Daily data download complete for ESU1.CME. Unique request ID: 1 | 2021-08-23 09:13:54.604 Removing historical data download ID 1. | 2021-08-23 09:13:54.604 Triggering next historical data download in queue. | 2021-08-23 09:13:54.604 Mapping NQU1.CME to NQU21. Service code: cme | 2021-08-23 09:13:54.604 HD Request # 3 | Downloading Historical Daily chart data for NQU1.CME. Starting date: 2021-08-19. Service: rithmic.trading | 2021-08-23 09:13:54.606 ESU1.CME [CV] Rev. 4t #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-08-23 09:13:54.607 ESU1.CME [CV] Rev. 4t #1 | Reloading chart. | 2021-08-23 09:13:54.608 ESU1.CME [CV] Rev. 4t #1 | Reloading chart. | 2021-08-23 09:13:54.616 ESU1.CME [CV] Rev. 4t #1 | File ESU1.CME.dly has a volume of 0 at 2021-08-23. | 2021-08-23 09:13:54.636 HD Request # 3 | Requesting historical Daily data for NQU21 starting at 2021-08-18. SC External HD service. | 2021-08-23 09:13:54.887 HD Request # 3 | Receiving historical Daily data for NQU1.CME starting at 2021-08-19 | 2021-08-23 09:13:55.430 HD Request # 3 | Writing historical Daily data to the file NQU1.CME.dly | 2021-08-23 09:13:55.430 HD Request # 3 | Bytes received: 235 | 2021-08-23 09:13:55.434 HD Request # 3 | Received 4 Daily data records from 2021-08-19 00:00:00 to 2021-08-23 00:00:00 (5.0 days) and wrote 3 records for NQU1.CME | 2021-08-23 09:13:55.434 HD Request # 3 | Completion time: 1s | 2021-08-23 09:13:55.434 HD Request # 3 | Daily data download complete for NQU1.CME. Unique request ID: 2 | 2021-08-23 09:13:55.434 Removing historical data download ID 2. | 2021-08-23 09:13:55.434 Triggering next historical data download in queue. | 2021-08-23 09:13:55.434 No download requests in the queue to start downloads for. | 2021-08-23 09:13:55.435 NQU1.CME [CV] Rev. 16t #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-08-23 09:13:55.435 NQU1.CME [CV] Rev. 16t #4 | Reloading chart. | 2021-08-23 09:13:55.436 NQU1.CME [CV] Rev. 16t #4 | Reloading chart. | 2021-08-23 09:13:55.443 NQU1.CME [CV] Rev. 16t #4 | File NQU1.CME.dly has a volume of 0 at 2021-08-23. | 2021-08-23 09:13:55.464 Added historical Intraday data request for NQU1.CME to the queue. | 2021-08-23 09:13:55.469 Intraday data recording state for symbol NQU1.CME is set to download 'Pending'. | 2021-08-23 09:13:55.469 Triggering next historical data download in queue. | 2021-08-23 09:13:55.469 HD Request # 4 | Downloading Intraday chart data for NQU1.CME to the file NQU1.CME.scid. Service: cme | 2021-08-23 09:13:55.469 HD Request # 4 | Download start date-time: 2021-08-23 09:10:31.000000. File last date-time: 2021-08-23 09:10:31.827001 | 2021-08-23 09:13:55.469 HD Request # 4 | Using server: ds21.sierracharts.com port 10149 | 2021-08-23 09:13:55.469 Socket (1) | Creating socket. | 2021-08-23 09:13:55.470 Socket (1) | New receive buffer size: 5242880 | 2021-08-23 09:13:55.470 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-08-23 09:13:55.470 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-08-23 09:13:55.544 DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2021-08-23 09:13:55.544 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-08-23 09:13:55.544 DTC Client socket (3) | Connecting to IP: 216.57.156.163. | 2021-08-23 09:13:55.544 Rithmic Direct - DTC | Network connection to server complete. | 2021-08-23 09:13:55.658 Rithmic Direct - DTC | Starting socket receive thread. | 2021-08-23 09:13:55.658 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-08-23 09:13:55.658 Rithmic Direct - DTC | Sending logon request message. | 2021-08-23 09:13:55.658 HD Request # 4 | Setting DTC encoding to Binary VLS | 2021-08-23 09:13:55.696 HD Request # 4 | Sending historical data logon request message. | 2021-08-23 09:13:55.696 Rithmic Direct - DTC | Received logon response. | 2021-08-23 09:13:56.113 Rithmic Direct - DTC | Server Name: . | 2021-08-23 09:13:56.113 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2021-08-23 09:13:56.113 Rithmic Direct - DTC | Successfully connected. | 2021-08-23 09:13:56.113 Rithmic Direct - DTC | Trading is supported. | 2021-08-23 09:13:56.113 Rithmic Direct - DTC | Order cancel and replace is supported. | 2021-08-23 09:13:56.113 Rithmic Direct - DTC | OCO Orders supported. | 2021-08-23 09:13:56.113 Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2021-08-23 09:13:56.113 Rithmic Direct - DTC | Connected to server complete. | 2021-08-23 09:13:56.113 Triggering next historical data download in queue. | 2021-08-23 09:13:56.113 Triggering next historical data download in queue. | 2021-08-23 09:13:56.113 Triggering next historical data download in queue. | 2021-08-23 09:13:56.113 Triggering next historical data download in queue. | 2021-08-23 09:13:56.113 No download requests in the queue to start downloads for. | 2021-08-23 09:13:56.121 No download requests in the queue to start downloads for. | 2021-08-23 09:13:56.121 No download requests in the queue to start downloads for. | 2021-08-23 09:13:56.121 Mapping ESU1.CME to ESU21. Service code: cme | 2021-08-23 09:13:56.121 SC Data - All Services | Starting real-time market data updates for: ESU1.CME (ESU21). ID: 1 Service code: cme | 2021-08-23 09:13:56.121 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2021-08-23 09:13:56.121 SC Data - All Services | Requesting security definition data for: ESU1.CME (ESU21). ID: 1 | 2021-08-23 09:13:56.121 Requesting market depth updates for: ESU1.CME if supported. | 2021-08-23 09:13:56.121 Separate subscription for market depth updates not supported. ESU1.CME | 2021-08-23 09:13:56.121 Added historical Intraday data request for ESU1.CME to the queue. | 2021-08-23 09:13:56.121 Intraday data recording state for symbol ESU1.CME is set to download 'Pending'. | 2021-08-23 09:13:56.121 Triggering next historical data download in queue. | 2021-08-23 09:13:56.121 DTC Client socket (2) | Creating socket. | 2021-08-23 09:13:56.122 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-08-23 09:13:56.122 DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2021-08-23 09:13:56.122 Mapping NQU1.CME to NQU21. Service code: cme | 2021-08-23 09:13:56.125 SC Data - All Services | Starting real-time market data updates for: NQU1.CME (NQU21). ID: 2 Service code: cme | 2021-08-23 09:13:56.125 SC Data - All Services | Requesting security definition data for: NQU1.CME (NQU21). ID: 2 | 2021-08-23 09:13:56.125 SC Data - All Services | Network connection to server complete. | 2021-08-23 09:13:56.230 SC Data - All Services | Starting socket receive thread. | 2021-08-23 09:13:56.230 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-08-23 09:13:56.230 HD Request # 4 | Requesting Intraday data. Start date-time: 2021-08-23 09:10:31. Record interval: 0. Symbol: NQU21 | 2021-08-23 09:13:56.259 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-08-23 09:13:56.362 SC Data - All Services | Sending logon request message. | 2021-08-23 09:13:56.362 HD Request # 4 | Decompressing data. | 2021-08-23 09:13:56.368 HD Request # 4 | Receiving Intraday data for NQU1.CME starting at 2021-08-23 09:10:31.007000 | 2021-08-23 09:13:56.369 Socket (1) | CloseSocket call. | 2021-08-23 09:13:56.370 HD Request # 4 | Re-requesting historical data for NQU1.CME to get the latest data since the download was started while not connected to primary service. | 2021-08-23 09:13:56.370 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-08-23 09:13:56.370 Added historical Intraday data request for NQU1.CME to the queue. | 2021-08-23 09:13:56.370 Intraday data recording state for symbol NQU1.CME is set to download 'Pending'. | 2021-08-23 09:13:56.370 Triggering next historical data download in queue. | 2021-08-23 09:13:56.370 Historical data download thread signaled to stop. | 2021-08-23 09:13:56.370 HD Request # 4 | Timestamp of first Intraday data file record written: 2021-08-23 09:10:35.171000 | 2021-08-23 09:13:56.370 HD Request # 4 | Received 423 Intraday data records from 2021-08-23 09:10:31.007000 to 2021-08-23 09:13:52.993001 (3.4 minutes) and wrote 420 records for NQU1.CME | 2021-08-23 09:13:56.370 HD Request # 4 | Completion time: 1s | 2021-08-23 09:13:56.370 Delaying start of download for NQU1.CME | 2021-08-23 09:13:56.370 Socket (1) | Socket gracefully closed by remote side. | 2021-08-23 09:13:56.479 Socket (1) | Closed. | 2021-08-23 09:13:56.479 SC Data - All Services | Received logon response. | 2021-08-23 09:13:57.193 SC Data - All Services | Server Name: SC Realtime Server. | 2021-08-23 09:13:57.193 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-08-23 09:13:57.193 SC Data - All Services | Successfully connected. | 2021-08-23 09:13:57.193 SC Data - All Services | Trading is not supported. | 2021-08-23 09:13:57.193 SC Data - All Services | Restarting real-time data updates for symbol: ESU1.CME -> ESU21. Market Depth data restarted. | 2021-08-23 09:13:57.193 SC Data - All Services | Restarting real-time data updates for symbol: NQU1.CME -> NQU21 | 2021-08-23 09:13:57.193 SC Data - All Services | Clearing market depth for ESU1.CME | 2021-08-23 09:13:57.380 SC Data - All Services | Received security definition for symbol ESU1.CME | 2021-08-23 09:13:57.380 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESU1.CME.2021-08-23.depth | 2021-08-23 09:13:57.381 SC Data - All Services | Received security definition for symbol NQU1.CME | 2021-08-23 09:13:57.381 Created process C:\SierraChart\SierraChartInstance_2\SierraChart_64.exe. Current folder: C:\SierraChart\SierraChartInstance_2 | 2021-08-23 09:13:57.789 Created process C:\SierraChart\SierraChartInstance_3\SierraChart_64.exe. Current folder: C:\SierraChart\SierraChartInstance_3 | 2021-08-23 09:13:58.018 Created process C:\SierraChart\SierraChartInstance_4\SierraChart_64.exe. Current folder: C:\SierraChart\SierraChartInstance_4 | 2021-08-23 09:13:58.253 Created process C:\SierraChart\SierraChartInstance_5\SierraChart_64.exe. Current folder: C:\SierraChart\SierraChartInstance_5 | 2021-08-23 09:13:58.487 Created process C:\SierraChart\SierraChartInstance_6\SierraChart_64.exe. Current folder: C:\SierraChart\SierraChartInstance_6 | 2021-08-23 09:13:58.710 + Loading additional symbol data. | 2021-08-23 09:13:59.004 Loading market depth data. | 2021-08-23 09:13:59.664 ESU1.CME [CV][M] Rev. 4t #1 | StartDateTimeForLoadingOrderFills: 2021-07-13 00:00:00 | 2021-08-23 09:13:59.834 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE_NASDAQ_NYSEMKT. ID: 3 Service code: statscalc | 2021-08-23 09:13:59.836 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2021-08-23 09:13:59.836 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE_NASDAQ_NYSEMKT. ID: 3 | 2021-08-23 09:13:59.837 Added historical Intraday data request for TICK-NYSE_NASDAQ_NYSEMKT to the queue. | 2021-08-23 09:13:59.837 Intraday data recording state for symbol TICK-NYSE_NASDAQ_NYSEMKT is set to download 'Pending'. | 2021-08-23 09:13:59.837 Triggering next historical data download in queue. | 2021-08-23 09:13:59.837 ESU1.CME [CV][M] Rev. 4t #1 | Started historical data download for additional symbol TICK-NYSE_NASDAQ_NYSEMKT. Download ID: 6 | 2021-08-23 09:13:59.837 DTC Client socket (1) | Creating socket. | 2021-08-23 09:13:59.837 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-08-23 09:13:59.837 DTC Client socket (1) | Connecting to IP: 204.15.197.14. | 2021-08-23 09:13:59.837 Loaded depth data records for ESU1.CME 2021-08-13 from 2021-08-13 14:04:56.538000 to 2021-08-13 23:36:35.984000. | 2021-08-23 09:14:00.084 Loaded depth data records for ESU1.CME 2021-08-15 from 2021-08-15 23:30:00.512000 to 2021-08-16 01:59:59.984000. | 2021-08-23 09:14:00.097 + Loading additional symbol data. | 2021-08-23 09:14:00.388 Loaded depth data records for ESU1.CME 2021-08-16 from 2021-08-16 02:00:00.005000 to 2021-08-16 22:49:24.780106. | 2021-08-23 09:14:00.882 SC DTC Data with Market Depth | Network connection to server complete. | 2021-08-23 09:14:01.305 SC DTC Data with Market Depth | Starting socket receive thread. | 2021-08-23 09:14:01.305 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2021-08-23 09:14:01.305 ESU1.CME [C][M] Point & Figure 10-1 #6 | StartDateTimeForLoadingOrderFills: 2021-07-26 00:00:00 | 2021-08-23 09:14:01.306 NQU1.CME [CV][M] Rev. 16t #4 | StartDateTimeForLoadingOrderFills: 2021-07-13 00:00:00 | 2021-08-23 09:14:01.311 Loaded depth data records for ESU1.CME 2021-08-17 from 2021-08-17 12:45:17.228000 to 2021-08-18 01:21:24.887085. | 2021-08-23 09:14:02.136 Loaded depth data records for ESU1.CME 2021-08-18 from 2021-08-18 12:20:09.601000 to 2021-08-18 22:03:45.874142. | 2021-08-23 09:14:03.120 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-08-23 09:14:04.491 SC DTC Data with Market Depth | Sending logon request message. | 2021-08-23 09:14:04.491 ESU1.CME [CV][M] Rev. 4t #1 | Reloading chart. | 2021-08-23 09:14:04.514 ESU1.CME [CV][M] Rev. 4t #1 | File ESU1.CME.dly has a volume of 0 at 2021-08-23. | 2021-08-23 09:14:04.534 NQU1.CME [CV][M] Rev. 16t #4 | Reloading chart. | 2021-08-23 09:14:04.553 NQU1.CME [CV][M] Rev. 16t #4 | File NQU1.CME.dly has a volume of 0 at 2021-08-23. | 2021-08-23 09:14:04.573 HD Request # 5 | Downloading Intraday chart data for NQU1.CME to the file NQU1.CME.scid. Service: cme | 2021-08-23 09:14:04.626 HD Request # 5 | Download start date-time: 2021-08-23 09:13:52.000000. File last date-time: 2021-08-23 09:13:52.993001 | 2021-08-23 09:14:04.627 HD Request # 5 | Using server: ds23.sierracharts.com port 10150 | 2021-08-23 09:14:04.627 Socket (4) | Creating socket. | 2021-08-23 09:14:04.627 Socket (4) | New receive buffer size: 5242880 | 2021-08-23 09:14:04.627 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-08-23 09:14:04.627 Requesting market depth updates for: NQU1.CME if supported. | 2021-08-23 09:14:04.631 SC Data - All Services | Clearing market depth for NQU1.CME | 2021-08-23 09:14:04.764 HD Request # 5 | Setting DTC encoding to Binary VLS | 2021-08-23 09:14:04.852 HD Request # 5 | Sending historical data logon request message. | 2021-08-23 09:14:04.852 Loaded depth data records for ESU1.CME 2021-08-19 from 2021-08-19 12:40:11.465000 to 2021-08-19 22:07:28.819921. | 2021-08-23 09:14:04.883 HD Request # 5 | Requesting Intraday data. Start date-time: 2021-08-23 09:13:52. Record interval: 0. Symbol: NQU21 | 2021-08-23 09:14:04.959 HD Request # 5 | Decompressing data. | 2021-08-23 09:14:05.067 HD Request # 5 | Receiving Intraday data for NQU1.CME starting at 2021-08-23 09:13:52.993000 | 2021-08-23 09:14:05.072 Socket (4) | CloseSocket call. | 2021-08-23 09:14:05.073 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-08-23 09:14:05.074 Historical data download thread signaled to stop. | 2021-08-23 09:14:05.078 HD Request # 5 | Timestamp of first Intraday data file record written: 2021-08-23 09:13:57.721000 | 2021-08-23 09:14:05.078 HD Request # 5 | Received 5 Intraday data records from 2021-08-23 09:13:52.993000 to 2021-08-23 09:14:01.431001 (8.4 seconds) and wrote 3 records for NQU1.CME | 2021-08-23 09:14:05.078 HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2021-08-23 07:14:01.431001 | 2021-08-23 09:14:05.078 Added 1 Time and Sales records to Intraday data file for NQU1.CME after download. | 2021-08-23 09:14:05.078 HD Request # 5 | Completion time: 1s | 2021-08-23 09:14:05.080 HD Request # 5 | Intraday data download complete for NQU1.CME. Unique request ID: 4 | 2021-08-23 09:14:05.080 Removing historical data download ID 4. | 2021-08-23 09:14:05.080 Real-time Intraday chart data file updates started for NQU1.CME | 2021-08-23 09:14:05.080 Intraday chart data file opened for NQU1.CME | 2021-08-23 09:14:05.080 HD Request # 5 | Enabling Intraday chart updating for symbol. | 2021-08-23 09:14:05.080 Triggering next historical data download in queue. | 2021-08-23 09:14:05.081 HD Request # 6 | Downloading Intraday chart data for ESU1.CME to the file ESU1.CME.scid. Service: cme | 2021-08-23 09:14:05.083 HD Request # 6 | Download start date-time: 2021-08-23 09:13:50.000000. File last date-time: 2021-08-23 09:13:50.412004 | 2021-08-23 09:14:05.083 HD Request # 6 | Using server: ds21.sierracharts.com port 10149 | 2021-08-23 09:14:05.086 Socket (5) | Creating socket. | 2021-08-23 09:14:05.086 Socket (5) | New receive buffer size: 5242880 | 2021-08-23 09:14:05.086 Socket (5) | Connecting to IP: 216.1.90.129. | 2021-08-23 09:14:05.086 Socket (4) | Socket gracefully closed by remote side. | 2021-08-23 09:14:05.181 Socket (4) | Closed. | 2021-08-23 09:14:05.181 SC DTC Data with Market Depth | Received logon response. | 2021-08-23 09:14:05.245 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2021-08-23 09:14:05.245 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2021-08-23 09:14:05.245 SC DTC Data with Market Depth | Successfully connected. | 2021-08-23 09:14:05.245 SC DTC Data with Market Depth | Trading is not supported. | 2021-08-23 09:14:05.245 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE_NASDAQ_NYSEMKT | 2021-08-23 09:14:05.245 HD Request # 6 | Setting DTC encoding to Binary VLS | 2021-08-23 09:14:05.313 HD Request # 6 | Sending historical data logon request message. | 2021-08-23 09:14:05.313 HD Request # 6 | Requesting Intraday data. Start date-time: 2021-08-23 09:13:50. Record interval: 0. Symbol: ESU21 | 2021-08-23 09:14:05.423 SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE_NASDAQ_NYSEMKT | 2021-08-23 09:14:05.462 HD Request # 6 | Decompressing data. | 2021-08-23 09:14:05.533 HD Request # 6 | Receiving Intraday data for ESU1.CME starting at 2021-08-23 09:13:50.206000 | 2021-08-23 09:14:05.536 Socket (5) | CloseSocket call. | 2021-08-23 09:14:05.537 Socket (5) | Shutdown started. Waiting for graceful close. | 2021-08-23 09:14:05.537 Historical data download thread signaled to stop. | 2021-08-23 09:14:05.538 HD Request # 6 | Timestamp of first Intraday data file record written: 2021-08-23 09:13:51.322000 | 2021-08-23 09:14:05.538 HD Request # 6 | Received 32 Intraday data records from 2021-08-23 09:13:50.206000 to 2021-08-23 09:14:02.296004 (12.1 seconds) and wrote 22 records for ESU1.CME | 2021-08-23 09:14:05.538 HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2021-08-23 07:14:02.296004 | 2021-08-23 09:14:05.538 Added 3 Time and Sales records to Intraday data file for ESU1.CME after download. | 2021-08-23 09:14:05.538 HD Request # 6 | Completion time: 0s | 2021-08-23 09:14:05.540 HD Request # 6 | Intraday data download complete for ESU1.CME. Unique request ID: 5 | 2021-08-23 09:14:05.540 Removing historical data download ID 5. | 2021-08-23 09:14:05.540 Real-time Intraday chart data file updates started for ESU1.CME | 2021-08-23 09:14:05.540 Intraday chart data file opened for ESU1.CME | 2021-08-23 09:14:05.540 HD Request # 6 | Enabling Intraday chart updating for symbol. | 2021-08-23 09:14:05.540 Triggering next historical data download in queue. | 2021-08-23 09:14:05.540 Delaying start of download for TICK-NYSE_NASDAQ_NYSEMKT | 2021-08-23 09:14:05.543 Socket (5) | Socket gracefully closed by remote side. | 2021-08-23 09:14:05.649 Socket (5) | Closed. | 2021-08-23 09:14:05.649 Loaded depth data records for ESU1.CME 2021-08-20 from 2021-08-20 08:56:08.631000 to 2021-08-20 23:00:00.064000. | 2021-08-23 09:14:05.993 Loaded depth data records for ESU1.CME 2021-08-22 from 2021-08-23 00:18:59.926000 to 2021-08-23 00:23:10.570326. | 2021-08-23 09:14:05.994 Enabling compression for file: C:\SierraChart\Data\MarketDepthData\ESU1.CME.2021-08-23.depth. This may take a while. | 2021-08-23 09:14:05.994 File compression enabled. C:\SierraChart\Data\MarketDepthData\ESU1.CME.2021-08-23.depth. CompressionState=0 | 2021-08-23 09:14:05.994 Loaded depth data records for ESU1.CME 2021-08-23 from 00:00:00.000000 to 00:00:00.000000. | 2021-08-23 09:14:05.995 ESU1.CME[M] 10000 Volume #3 | StartDateTimeForLoadingOrderFills: 2021-07-26 00:00:00 | 2021-08-23 09:14:05.998 + Loading additional symbol data. | 2021-08-23 09:14:08.844 Opened cached Intraday file: C:\SierraChart\Data\ESU1.CME.scid. Thread ID: 8772 | 2021-08-23 09:14:09.074 Opened cached Intraday file: C:\SierraChart\Data\NQU1.CME.scid. Thread ID: 8772 | 2021-08-23 09:14:09.074 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:09.347 HD Server Manager | Started new historical data server. Count=1 | 2021-08-23 09:14:09.347 HD Server | Thread:1084 (4) | Creating socket. | 2021-08-23 09:14:09.362 HD Server | Thread:1084 (4) | New receive buffer size: 262144 | 2021-08-23 09:14:09.362 HD Server | Thread:1084 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:09.362 HD Server | Setting DTC encoding to Binary VLS | Thread:1084 | 2021-08-23 09:14:09.362 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:1084 | 2021-08-23 09:14:09.363 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:1084 | 2021-08-23 09:14:09.363 HD Server | HD Request #1 | Socket: 4 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-08-19 00:00:00 | ClientReqID: 1 | Username: Kza57SC. | Thread:1084 | 2021-08-23 09:14:09.364 HD Server | HD Request | Socket: 4 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 1 | Username: Kza57SC. | Thread:1084 | 2021-08-23 09:14:09.369 HD Server | Thread:1084 (4) | Socket gracefully closed by remote side. | 2021-08-23 09:14:09.372 HD Server | Thread:1084 (4) | CloseSocket call. | 2021-08-23 09:14:09.372 HD Server | Thread:1084 (0) | CloseSocket call. | 2021-08-23 09:14:09.373 HD Server | Thread:1084 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:09.373 HD Server | Thread:1084 (4) | Closed. | 2021-08-23 09:14:09.373 HD Server | Thread:1084 (0) | CloseSocket call. | 2021-08-23 09:14:09.373 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:09.380 HD Server Manager | Started new historical data server. Count=2 | 2021-08-23 09:14:09.381 HD Server | Thread:7584 (4) | Creating socket. | 2021-08-23 09:14:09.395 HD Server | Thread:7584 (4) | New receive buffer size: 262144 | 2021-08-23 09:14:09.395 HD Server | Thread:7584 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:09.396 HD Server | Setting DTC encoding to Binary VLS | Thread:7584 | 2021-08-23 09:14:09.396 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:7584 | 2021-08-23 09:14:09.397 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:7584 | 2021-08-23 09:14:09.397 HD Server | HD Request #2 | Socket: 4 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-08-19 00:00:00 | ClientReqID: 2 | Username: Kza57SC. | Thread:7584 | 2021-08-23 09:14:09.398 HD Server | HD Request | Socket: 4 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 2 | Username: Kza57SC. | Thread:7584 | 2021-08-23 09:14:09.402 HD Server | Thread:7584 (4) | Socket gracefully closed by remote side. | 2021-08-23 09:14:09.405 HD Server | Thread:7584 (4) | CloseSocket call. | 2021-08-23 09:14:09.405 HD Server | Thread:7584 (0) | CloseSocket call. | 2021-08-23 09:14:09.406 HD Server | Thread:7584 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:09.406 HD Server | Thread:7584 (4) | Closed. | 2021-08-23 09:14:09.406 HD Server | Thread:7584 (0) | CloseSocket call. | 2021-08-23 09:14:09.406 + Loading additional symbol data. | 2021-08-23 09:14:09.428 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:09.529 HD Server Manager | Started new historical data server. Count=3 | 2021-08-23 09:14:09.530 HD Server | Thread:8640 (4) | Creating socket. | 2021-08-23 09:14:09.550 HD Server | Thread:8640 (4) | New receive buffer size: 262144 | 2021-08-23 09:14:09.550 HD Server | Thread:8640 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:09.551 HD Server | Setting DTC encoding to Binary VLS | Thread:8640 | 2021-08-23 09:14:09.551 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:8640 | 2021-08-23 09:14:09.552 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:8640 | 2021-08-23 09:14:09.552 HD Server | HD Request #3 | Socket: 4 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-08-23 07:11:16 | ClientReqID: 3 | Username: Kza57SC. | Thread:8640 | 2021-08-23 09:14:09.552 HD Server | HD Request | Socket: 4 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 487 | ClientReqID: 3 | Username: Kza57SC. | Thread:8640 | 2021-08-23 09:14:09.554 HD Server | Thread:8640 (4) | Socket gracefully closed by remote side. | 2021-08-23 09:14:09.559 HD Server | Thread:8640 (4) | CloseSocket call. | 2021-08-23 09:14:09.559 HD Server | Thread:8640 (0) | CloseSocket call. | 2021-08-23 09:14:09.560 HD Server | Thread:8640 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:09.560 HD Server | Thread:8640 (4) | Closed. | 2021-08-23 09:14:09.560 HD Server | Thread:8640 (0) | CloseSocket call. | 2021-08-23 09:14:09.560 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:8640 | 2021-08-23 09:14:09.599 HD Server Manager | Current server count=2 | 2021-08-23 09:14:09.599 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:7584 | 2021-08-23 09:14:09.602 HD Server Manager | Current server count=1 | 2021-08-23 09:14:09.602 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:1084 | 2021-08-23 09:14:09.604 HD Server Manager | Current server count=0 | 2021-08-23 09:14:09.604 ESU1.CME [CV][M] Rev. 4t #1 | StartDateTimeForLoadingOrderFills: 2021-07-13 00:00:00 | 2021-08-23 09:14:09.673 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:11.416 HD Server Manager | Started new historical data server. Count=1 | 2021-08-23 09:14:11.417 NQU1.CME [CV][M] Rev. 16t #4 | StartDateTimeForLoadingOrderFills: 2021-07-13 00:00:00 | 2021-08-23 09:14:11.433 HD Server | Thread:7472 (4) | Creating socket. | 2021-08-23 09:14:11.445 HD Server | Thread:7472 (4) | New receive buffer size: 262144 | 2021-08-23 09:14:11.445 HD Server | Thread:7472 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:11.445 HD Server | Setting DTC encoding to Binary VLS | Thread:7472 | 2021-08-23 09:14:11.446 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:7472 | 2021-08-23 09:14:11.465 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:7472 | 2021-08-23 09:14:11.466 HD Server | HD Request #4 | Socket: 4 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-08-23 07:11:17 | ClientReqID: 4 | Username: Kza57SC. | Thread:7472 | 2021-08-23 09:14:11.468 HD Server | HD Request | Socket: 4 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 315 | ClientReqID: 4 | Username: Kza57SC. | Thread:7472 | 2021-08-23 09:14:11.470 HD Server | Thread:7472 (4) | Socket gracefully closed by remote side. | 2021-08-23 09:14:11.577 HD Server | Thread:7472 (4) | CloseSocket call. | 2021-08-23 09:14:11.581 HD Server | Thread:7472 (0) | CloseSocket call. | 2021-08-23 09:14:11.582 HD Server | Thread:7472 (0) | CloseSocket call. | 2021-08-23 09:14:11.582 HD Server | Thread:7472 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:11.592 HD Server | Thread:7472 (4) | Closed. | 2021-08-23 09:14:11.592 DTC Protocol server | Incoming connection from 127.0.0.1. | 2021-08-23 09:14:13.190 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:13.203 DTC client #1. 127.0.0.1 (4) | Creating socket. | 2021-08-23 09:14:13.203 DTC client #1. 127.0.0.1 (4) | New receive buffer size: 262144 | 2021-08-23 09:14:13.203 HD Server Manager | Started new historical data server. Count=2 | 2021-08-23 09:14:13.203 DTC client #1. 127.0.0.1 (4) | Allocated send buffers: 32 of 131072 bytes. | 2021-08-23 09:14:13.206 HD Server | Thread:8736 (5) | Creating socket. | 2021-08-23 09:14:13.381 HD Server | Thread:8736 (5) | New receive buffer size: 262144 | 2021-08-23 09:14:13.381 HD Server | Thread:8736 (5) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:13.382 HD Server | Setting DTC encoding to Binary VLS | Thread:8736 | 2021-08-23 09:14:13.382 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:8736 | 2021-08-23 09:14:13.418 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:8736 | 2021-08-23 09:14:13.418 HD Server | HD Request #1 | Socket: 5 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-08-23 07:11:13 | ClientReqID: 1 | Username: Kza57SC. | Thread:8736 | 2021-08-23 09:14:13.436 HD Server | HD Request | Socket: 5 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 489 | ClientReqID: 1 | Username: Kza57SC. | Thread:8736 | 2021-08-23 09:14:13.438 HD Server | Thread:8736 (5) | Socket gracefully closed by remote side. | 2021-08-23 09:14:13.439 HD Server | Thread:8736 (5) | CloseSocket call. | 2021-08-23 09:14:13.439 HD Server | Thread:8736 (0) | CloseSocket call. | 2021-08-23 09:14:13.440 HD Server | Thread:8736 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:13.440 HD Server | Thread:8736 (5) | Closed. | 2021-08-23 09:14:13.440 HD Server | Thread:8736 (0) | CloseSocket call. | 2021-08-23 09:14:13.440 DTC Protocol server | Incoming connection from 127.0.0.1. | 2021-08-23 09:14:14.940 DTC client #2. 127.0.0.1 (5) | Creating socket. | 2021-08-23 09:14:14.947 DTC client #2. 127.0.0.1 (5) | New receive buffer size: 262144 | 2021-08-23 09:14:14.947 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:14.947 HD Server Manager | Started new historical data server. Count=3 | 2021-08-23 09:14:14.947 DTC client #1. 127.0.0.1 | Set DTC encoding to Binary VLS | 2021-08-23 09:14:14.948 DTC Protocol server | Incoming connection from 127.0.0.1. | 2021-08-23 09:14:14.948 DTC client #2. 127.0.0.1 (5) | Allocated send buffers: 32 of 131072 bytes. | 2021-08-23 09:14:14.949 DTC client #3. 127.0.0.1 (6) | Creating socket. | 2021-08-23 09:14:14.965 DTC client #3. 127.0.0.1 (6) | New receive buffer size: 262144 | 2021-08-23 09:14:14.965 DTC client #3. 127.0.0.1 (6) | Allocated send buffers: 32 of 131072 bytes. | 2021-08-23 09:14:14.968 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:14.978 HD Server Manager | Started new historical data server. Count=4 | 2021-08-23 09:14:14.978 DTC Protocol server | Incoming connection from 127.0.0.1. | 2021-08-23 09:14:14.983 HD Server | Thread:6932 (7) | Creating socket. | 2021-08-23 09:14:14.987 HD Server | Thread:6932 (7) | New receive buffer size: 262144 | 2021-08-23 09:14:14.987 HD Server | Thread:6932 (7) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:14.987 HD Server | Setting DTC encoding to Binary VLS | Thread:6932 | 2021-08-23 09:14:14.993 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:6932 | 2021-08-23 09:14:15.000 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:6932 | 2021-08-23 09:14:15.000 DTC client #4. 127.0.0.1 (8) | Creating socket. | 2021-08-23 09:14:15.007 DTC client #4. 127.0.0.1 (8) | New receive buffer size: 262144 | 2021-08-23 09:14:15.007 HD Server | HD Request #1 | Socket: 7 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-08-23 07:11:13 | ClientReqID: 1 | Username: Kza57SC. | Thread:6932 | 2021-08-23 09:14:15.007 DTC client #2. 127.0.0.1 | Set DTC encoding to Binary VLS | 2021-08-23 09:14:15.007 HD Server | HD Request | Socket: 7 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 502 | ClientReqID: 1 | Username: Kza57SC. | Thread:6932 | 2021-08-23 09:14:15.009 DTC client #4. 127.0.0.1 (8) | Allocated send buffers: 32 of 131072 bytes. | 2021-08-23 09:14:15.009 HD Server | Thread:10908 (9) | Creating socket. | 2021-08-23 09:14:15.014 HD Server | Thread:10908 (9) | New receive buffer size: 262144 | 2021-08-23 09:14:15.014 HD Server | Thread:10908 (9) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:15.014 HD Server | Thread:6932 (7) | Socket gracefully closed by remote side. | 2021-08-23 09:14:15.025 HD Server | Setting DTC encoding to Binary VLS | Thread:10908 | 2021-08-23 09:14:15.025 HD Server | Thread:6932 (7) | CloseSocket call. | 2021-08-23 09:14:15.025 DTC client #1. 127.0.0.1 | Requested heartbeat interval: 20 | 2021-08-23 09:14:15.026 DTC client #1. Sierra Chart. 127.0.0.1 | Received logon request. | 2021-08-23 09:14:15.026 DTC client #1. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Kza57SC. Result text: Connected to SC DTC Protocol server. Service=rithmic_v2.trading|SymbolSettings=rithmic_v2.trading | 2021-08-23 09:14:15.026 HD Server | Thread:6932 (0) | CloseSocket call. | 2021-08-23 09:14:15.027 HD Server | Thread:6932 (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:15.027 HD Server | Thread:6932 (7) | Closed. | 2021-08-23 09:14:15.027 HD Server | Thread:6932 (0) | CloseSocket call. | 2021-08-23 09:14:15.027 DTC client #3. 127.0.0.1 | Set DTC encoding to Binary VLS | 2021-08-23 09:14:15.027 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:10908 | 2021-08-23 09:14:15.027 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:10908 | 2021-08-23 09:14:15.027 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:15.027 HD Server Manager | Started new historical data server. Count=5 | 2021-08-23 09:14:15.028 DTC Protocol server | Incoming connection from 127.0.0.1. | 2021-08-23 09:14:15.028 HD Server | HD Request #1 | Socket: 9 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-08-19 00:00:00 | ClientReqID: 1 | Username: Kza57SC. | Thread:10908 | 2021-08-23 09:14:15.028 HD Server | HD Request | Socket: 9 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 1 | Username: Kza57SC. | Thread:10908 | 2021-08-23 09:14:15.032 HD Server | Thread:10908 (9) | Socket gracefully closed by remote side. | 2021-08-23 09:14:15.047 HD Server | Thread:10908 (9) | CloseSocket call. | 2021-08-23 09:14:15.047 HD Server | Thread:10908 (0) | CloseSocket call. | 2021-08-23 09:14:15.054 HD Server | Thread:10908 (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:15.054 HD Server | Thread:10908 (9) | Closed. | 2021-08-23 09:14:15.054 DTC client #5. 127.0.0.1 (7) | Creating socket. | 2021-08-23 09:14:15.054 DTC client #5. 127.0.0.1 (7) | New receive buffer size: 262144 | 2021-08-23 09:14:15.054 HD Server | Thread:10908 (0) | CloseSocket call. | 2021-08-23 09:14:15.054 DTC client #5. 127.0.0.1 (7) | Allocated send buffers: 32 of 131072 bytes. | 2021-08-23 09:14:15.056 DTC client #4. 127.0.0.1 | Set DTC encoding to Binary VLS | 2021-08-23 09:14:15.058 HD Server | Thread:11984 (9) | Creating socket. | 2021-08-23 09:14:15.062 HD Server | Thread:11984 (9) | New receive buffer size: 262144 | 2021-08-23 09:14:15.062 HD Server | Thread:11984 (9) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:15.062 HD Server | Setting DTC encoding to Binary VLS | Thread:11984 | 2021-08-23 09:14:15.065 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:11984 | 2021-08-23 09:14:15.069 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:11984 | 2021-08-23 09:14:15.069 DTC client #2. 127.0.0.1 | Requested heartbeat interval: 20 | 2021-08-23 09:14:15.070 DTC client #2. Sierra Chart. 127.0.0.1 | Received logon request. | 2021-08-23 09:14:15.070 DTC client #2. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Kza57SC. Result text: Connected to SC DTC Protocol server. Service=rithmic_v2.trading|SymbolSettings=rithmic_v2.trading | 2021-08-23 09:14:15.070 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:15.070 HD Server | HD Request #1 | Socket: 9 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-08-23 07:10:31 | ClientReqID: 1 | Username: Kza57SC. | Thread:11984 | 2021-08-23 09:14:15.070 HD Server Manager | Started new historical data server. Count=6 | 2021-08-23 09:14:15.071 DTC client #5. 127.0.0.1 | Set DTC encoding to Binary VLS | 2021-08-23 09:14:15.071 HD Server | HD Request | Socket: 9 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 711 | ClientReqID: 1 | Username: Kza57SC. | Thread:11984 | 2021-08-23 09:14:15.075 HD Server | Thread:11984 (9) | Socket gracefully closed by remote side. | 2021-08-23 09:14:15.084 HD Server | Thread:11984 (9) | CloseSocket call. | 2021-08-23 09:14:15.085 DTC client #3. 127.0.0.1 | Requested heartbeat interval: 20 | 2021-08-23 09:14:15.089 DTC client #3. Sierra Chart. 127.0.0.1 | Received logon request. | 2021-08-23 09:14:15.089 DTC client #3. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Kza57SC. Result text: Connected to SC DTC Protocol server. Service=rithmic_v2.trading|SymbolSettings=rithmic_v2.trading | 2021-08-23 09:14:15.089 HD Server | Thread:11984 (0) | CloseSocket call. | 2021-08-23 09:14:15.092 HD Server | Thread:11984 (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:15.092 HD Server | Thread:11984 (9) | Closed. | 2021-08-23 09:14:15.092 HD Server | Thread:11984 (0) | CloseSocket call. | 2021-08-23 09:14:15.092 HD Server | Thread:1728 (9) | Creating socket. | 2021-08-23 09:14:15.101 HD Server | Thread:1728 (9) | New receive buffer size: 262144 | 2021-08-23 09:14:15.102 HD Server | Thread:1728 (9) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:15.102 HD Server | Setting DTC encoding to Binary VLS | Thread:1728 | 2021-08-23 09:14:15.105 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:1728 | 2021-08-23 09:14:15.109 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:1728 | 2021-08-23 09:14:15.109 DTC client #4. 127.0.0.1 | Requested heartbeat interval: 20 | 2021-08-23 09:14:15.110 DTC client #4. Sierra Chart. 127.0.0.1 | Received logon request. | 2021-08-23 09:14:15.110 DTC client #4. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Kza57SC. Result text: Connected to SC DTC Protocol server. Service=rithmic_v2.trading|SymbolSettings=rithmic_v2.trading | 2021-08-23 09:14:15.110 HD Server | HD Request #2 | Socket: 9 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-08-23 07:11:09 | ClientReqID: 2 | Username: Kza57SC. | Thread:1728 | 2021-08-23 09:14:15.110 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:15.110 HD Server Manager | Started new historical data server. Count=7 | 2021-08-23 09:14:15.111 HD Server | HD Request | Socket: 9 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 322 | ClientReqID: 2 | Username: Kza57SC. | Thread:1728 | 2021-08-23 09:14:15.112 HD Server | Thread:1728 (9) | Socket gracefully closed by remote side. | 2021-08-23 09:14:15.118 HD Server | Thread:1728 (9) | CloseSocket call. | 2021-08-23 09:14:15.119 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:15.122 HD Server Manager | Started new historical data server. Count=8 | 2021-08-23 09:14:15.122 HD Server | Thread:1728 (0) | CloseSocket call. | 2021-08-23 09:14:15.126 HD Server | Thread:1728 (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:15.126 HD Server | Thread:1728 (9) | Closed. | 2021-08-23 09:14:15.126 HD Server | Thread:1728 (0) | CloseSocket call. | 2021-08-23 09:14:15.126 HD Server | Thread:5588 (9) | Creating socket. | 2021-08-23 09:14:15.144 HD Server | Thread:5588 (9) | New receive buffer size: 262144 | 2021-08-23 09:14:15.144 HD Server | Thread:5588 (9) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:15.144 HD Server | Setting DTC encoding to Binary VLS | Thread:5588 | 2021-08-23 09:14:15.145 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:5588 | 2021-08-23 09:14:15.152 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:5588 | 2021-08-23 09:14:15.152 HD Server | HD Request #2 | Socket: 9 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-08-19 00:00:00 | ClientReqID: 2 | Username: Kza57SC. | Thread:5588 | 2021-08-23 09:14:15.156 HD Server | HD Request | Socket: 9 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 2 | Username: Kza57SC. | Thread:5588 | 2021-08-23 09:14:15.164 HD Server | Thread:5596 (10) | Creating socket. | 2021-08-23 09:14:15.164 HD Server | Thread:5596 (10) | New receive buffer size: 262144 | 2021-08-23 09:14:15.164 HD Server | Thread:5596 (10) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:15.164 HD Server | Setting DTC encoding to Binary VLS | Thread:5596 | 2021-08-23 09:14:15.165 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:5596 | 2021-08-23 09:14:15.166 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:5596 | 2021-08-23 09:14:15.166 HD Server | HD Request #2 | Socket: 10 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-08-23 07:10:31 | ClientReqID: 2 | Username: Kza57SC. | Thread:5596 | 2021-08-23 09:14:15.167 HD Server | Thread:5588 (9) | Socket gracefully closed by remote side. | 2021-08-23 09:14:15.169 HD Server | Thread:5588 (9) | CloseSocket call. | 2021-08-23 09:14:15.169 HD Server | HD Request | Socket: 10 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 437 | ClientReqID: 2 | Username: Kza57SC. | Thread:5596 | 2021-08-23 09:14:15.169 HD Server | Thread:5588 (0) | CloseSocket call. | 2021-08-23 09:14:15.170 HD Server | Thread:5588 (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:15.170 HD Server | Thread:5588 (9) | Closed. | 2021-08-23 09:14:15.170 HD Server | Thread:5588 (0) | CloseSocket call. | 2021-08-23 09:14:15.170 HD Server | Thread:5596 (10) | Socket gracefully closed by remote side. | 2021-08-23 09:14:15.171 HD Server | Thread:5596 (10) | CloseSocket call. | 2021-08-23 09:14:15.172 HD Server | Thread:5596 (0) | CloseSocket call. | 2021-08-23 09:14:15.173 HD Server | Thread:5596 (10) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:15.173 HD Server | Thread:5596 (10) | Closed. | 2021-08-23 09:14:15.173 HD Server | Thread:5596 (0) | CloseSocket call. | 2021-08-23 09:14:15.173 DTC client #5. 127.0.0.1 | Requested heartbeat interval: 20 | 2021-08-23 09:14:15.412 DTC client #5. Sierra Chart. 127.0.0.1 | Received logon request. | 2021-08-23 09:14:15.412 DTC client #5. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Kza57SC. Result text: Connected to SC DTC Protocol server. Service=rithmic_v2.trading|SymbolSettings=rithmic_v2.trading | 2021-08-23 09:14:15.412 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:15.412 HD Server Manager | Started new historical data server. Count=9 | 2021-08-23 09:14:15.414 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:15.414 HD Server Manager | Started new historical data server. Count=10 | 2021-08-23 09:14:15.415 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:15.415 HD Server Manager | Started new historical data server. Count=11 | 2021-08-23 09:14:15.416 HD Server | Thread:2888 (9) | Creating socket. | 2021-08-23 09:14:15.452 HD Server | Thread:2888 (9) | New receive buffer size: 262144 | 2021-08-23 09:14:15.452 HD Server | Thread:2888 (9) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:15.452 HD Server | Setting DTC encoding to Binary VLS | Thread:2888 | 2021-08-23 09:14:15.455 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:2888 | 2021-08-23 09:14:15.462 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:2888 | 2021-08-23 09:14:15.462 HD Server | Thread:5576 (10) | Creating socket. | 2021-08-23 09:14:15.481 HD Server | Thread:5576 (10) | New receive buffer size: 262144 | 2021-08-23 09:14:15.481 HD Server | Thread:5576 (10) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:15.481 HD Server | Setting DTC encoding to Binary VLS | Thread:5576 | 2021-08-23 09:14:15.482 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:5576 | 2021-08-23 09:14:15.485 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:5576 | 2021-08-23 09:14:15.485 HD Server | HD Request #3 | Socket: 9 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-08-23 07:10:31 | ClientReqID: 3 | Username: Kza57SC. | Thread:2888 | 2021-08-23 09:14:15.486 HD Server | HD Request | Socket: 9 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 711 | ClientReqID: 3 | Username: Kza57SC. | Thread:2888 | 2021-08-23 09:14:15.488 HD Server | HD Request #3 | Socket: 10 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-08-23 07:14:11 | ClientReqID: 3 | Username: Kza57SC. | Thread:5576 | 2021-08-23 09:14:15.492 HD Server | Thread:1896 (11) | Creating socket. | 2021-08-23 09:14:15.492 HD Server | Thread:1896 (11) | New receive buffer size: 262144 | 2021-08-23 09:14:15.493 HD Server | Thread:1896 (11) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:15.493 HD Server | HD Request | Socket: 10 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientReqID: 3 | Username: Kza57SC. | Thread:5576 | 2021-08-23 09:14:15.493 HD Server | Setting DTC encoding to Binary VLS | Thread:1896 | 2021-08-23 09:14:15.493 HD Server | Thread:5576 (10) | Socket gracefully closed by remote side. | 2021-08-23 09:14:15.494 HD Server | Thread:5576 (10) | CloseSocket call. | 2021-08-23 09:14:15.494 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:1896 | 2021-08-23 09:14:15.494 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:1896 | 2021-08-23 09:14:15.494 HD Server | Thread:5576 (0) | CloseSocket call. | 2021-08-23 09:14:15.494 HD Server | Thread:5576 (10) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:15.495 HD Server | Thread:5576 (10) | Closed. | 2021-08-23 09:14:15.495 HD Server | Thread:2888 (9) | Socket gracefully closed by remote side. | 2021-08-23 09:14:15.495 HD Server | Thread:5576 (0) | CloseSocket call. | 2021-08-23 09:14:15.495 HD Server | Thread:2888 (9) | CloseSocket call. | 2021-08-23 09:14:15.495 HD Server | Thread:2888 (0) | CloseSocket call. | 2021-08-23 09:14:15.496 HD Server | HD Request #3 | Socket: 11 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-08-23 07:14:11 | ClientReqID: 3 | Username: Kza57SC. | Thread:1896 | 2021-08-23 09:14:15.496 HD Server | Thread:2888 (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:15.496 HD Server | Thread:2888 (9) | Closed. | 2021-08-23 09:14:15.496 HD Server | Thread:2888 (0) | CloseSocket call. | 2021-08-23 09:14:15.496 HD Server | HD Request | Socket: 11 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientReqID: 3 | Username: Kza57SC. | Thread:1896 | 2021-08-23 09:14:15.496 HD Server | Thread:1896 (11) | Socket gracefully closed by remote side. | 2021-08-23 09:14:15.497 HD Server | Thread:1896 (11) | CloseSocket call. | 2021-08-23 09:14:15.497 HD Server | Thread:1896 (0) | CloseSocket call. | 2021-08-23 09:14:15.497 HD Server | Thread:1896 (11) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:15.498 HD Server | Thread:1896 (11) | Closed. | 2021-08-23 09:14:15.498 HD Server | Thread:1896 (0) | CloseSocket call. | 2021-08-23 09:14:15.498 DTC client #2. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol ESU1.CME | 2021-08-23 09:14:15.544 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:15.544 HD Server Manager | Started new historical data server. Count=12 | 2021-08-23 09:14:15.545 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:1896 | 2021-08-23 09:14:15.564 HD Server Manager | Current server count=11 | 2021-08-23 09:14:15.564 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:5576 | 2021-08-23 09:14:15.564 HD Server Manager | Current server count=10 | 2021-08-23 09:14:15.564 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:2888 | 2021-08-23 09:14:15.564 HD Server Manager | Current server count=9 | 2021-08-23 09:14:15.565 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:5596 | 2021-08-23 09:14:15.565 HD Server Manager | Current server count=8 | 2021-08-23 09:14:15.565 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:5588 | 2021-08-23 09:14:15.565 HD Server Manager | Current server count=7 | 2021-08-23 09:14:15.565 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:1728 | 2021-08-23 09:14:15.565 HD Server Manager | Current server count=6 | 2021-08-23 09:14:15.565 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:11984 | 2021-08-23 09:14:15.565 HD Server Manager | Current server count=5 | 2021-08-23 09:14:15.565 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:10908 | 2021-08-23 09:14:15.565 HD Server Manager | Current server count=4 | 2021-08-23 09:14:15.565 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:6932 | 2021-08-23 09:14:15.565 HD Server Manager | Current server count=3 | 2021-08-23 09:14:15.565 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:8736 | 2021-08-23 09:14:15.565 HD Server Manager | Current server count=2 | 2021-08-23 09:14:15.565 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:7472 | 2021-08-23 09:14:15.565 HD Server Manager | Current server count=1 | 2021-08-23 09:14:15.565 HD Server | Thread:13768 (9) | Creating socket. | 2021-08-23 09:14:15.679 HD Server | Thread:13768 (9) | New receive buffer size: 262144 | 2021-08-23 09:14:15.679 HD Server | Thread:13768 (9) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:15.679 HD Server | Setting DTC encoding to Binary VLS | Thread:13768 | 2021-08-23 09:14:15.679 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:13768 | 2021-08-23 09:14:15.681 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:13768 | 2021-08-23 09:14:15.681 HD Server | HD Request #4 | Socket: 9 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-08-23 07:14:10 | ClientReqID: 4 | Username: Kza57SC. | Thread:13768 | 2021-08-23 09:14:15.681 HD Server | HD Request | Socket: 9 | Symbol: ESU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 13 | ClientReqID: 4 | Username: Kza57SC. | Thread:13768 | 2021-08-23 09:14:15.682 HD Server | Thread:13768 (9) | Socket gracefully closed by remote side. | 2021-08-23 09:14:15.683 HD Server | Thread:13768 (9) | CloseSocket call. | 2021-08-23 09:14:15.684 HD Server | Thread:13768 (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:15.684 HD Server | Thread:13768 (9) | Closed. | 2021-08-23 09:14:15.684 HD Server | Thread:13768 (0) | CloseSocket call. | 2021-08-23 09:14:15.684 HD Server | Thread:13768 (0) | CloseSocket call. | 2021-08-23 09:14:15.684 HD Request # 7 | Downloading Intraday chart data for TICK-NYSE_NASDAQ_NYSEMKT to the file TICK-NYSE_NASDAQ_NYSEMKT.scid. Service: statscalc | 2021-08-23 09:14:15.840 HD Request # 7 | Download start date-time: 2021-08-21 01:59:59.000000. File last date-time: 2021-08-21 01:59:59.000000 | 2021-08-23 09:14:15.840 HD Request # 7 | Using server: ds12.sierracharts.com port 10150 | 2021-08-23 09:14:15.840 Socket (9) | Creating socket. | 2021-08-23 09:14:15.849 Socket (9) | New receive buffer size: 5242880 | 2021-08-23 09:14:15.850 Socket (9) | Connecting to IP: 204.15.197.14. | 2021-08-23 09:14:15.850 HD Request # 7 | Setting DTC encoding to Binary VLS | 2021-08-23 09:14:16.103 HD Request # 7 | Sending historical data logon request message. | 2021-08-23 09:14:16.103 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:13768 | 2021-08-23 09:14:16.109 HD Server Manager | Current server count=0 | 2021-08-23 09:14:16.109 HD Request # 7 | Requesting Intraday data. Start date-time: 2021-08-21 01:59:59. Record interval: 0. Symbol: TICK-NYSE_NASDAQ_NYSEMKT | 2021-08-23 09:14:16.756 HD Request # 7 | Decompressing data. | 2021-08-23 09:14:16.874 HD Request # 7 | Receiving Intraday data for TICK-NYSE_NASDAQ_NYSEMKT starting at 2021-08-21 01:59:59.000000 | 2021-08-23 09:14:16.875 Socket (9) | CloseSocket call. | 2021-08-23 09:14:16.875 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-08-23 09:14:16.875 Historical data download thread signaled to stop. | 2021-08-23 09:14:16.901 HD Request # 7 | Received 1 Intraday data record from 2021-08-21 01:59:59.000000 to 2021-08-21 01:59:59.000000 (0.0 seconds) and wrote 0 records for TICK-NYSE_NASDAQ_NYSEMKT | 2021-08-23 09:14:16.901 HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2021-08-20 23:59:59.000000 | 2021-08-23 09:14:16.902 HD Request # 7 | Completion time: 1s | 2021-08-23 09:14:16.902 HD Request # 7 | Intraday data download complete for TICK-NYSE_NASDAQ_NYSEMKT. Unique request ID: 6 | 2021-08-23 09:14:16.902 Removing historical data download ID 6. | 2021-08-23 09:14:16.902 Real-time Intraday chart data file updates started for TICK-NYSE_NASDAQ_NYSEMKT | 2021-08-23 09:14:16.902 Intraday chart data file opened for TICK-NYSE_NASDAQ_NYSEMKT | 2021-08-23 09:14:16.902 HD Request # 7 | Enabling Intraday chart updating for symbol. | 2021-08-23 09:14:16.902 ESU1.CME [CV][M] Rev. 4t #1 | Historical data download for additional symbol TICK-NYSE_NASDAQ_NYSEMKT with ID 6 has completed. | 2021-08-23 09:14:16.902 Triggering next historical data download in queue. | 2021-08-23 09:14:16.902 No download requests in the queue to start downloads for. | 2021-08-23 09:14:16.902 Socket (9) | Socket gracefully closed by remote side. | 2021-08-23 09:14:16.994 Socket (9) | Closed. | 2021-08-23 09:14:16.994 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-08-23 09:14:20.223 HD Server Manager | Started new historical data server. Count=1 | 2021-08-23 09:14:20.223 HD Server | Thread:3496 (9) | Creating socket. | 2021-08-23 09:14:20.250 HD Server | Thread:3496 (9) | New receive buffer size: 262144 | 2021-08-23 09:14:20.250 HD Server | Thread:3496 (9) | Allocated send buffers: 32 of 4096 bytes. | 2021-08-23 09:14:20.250 HD Server | Setting DTC encoding to Binary VLS | Thread:3496 | 2021-08-23 09:14:20.250 HD Server | Received login. Requesting authorization. | Username: Kza57SC. | Thread:3496 | 2021-08-23 09:14:20.251 HD Server | Login has been authorized. | Username: Kza57SC. | Thread:3496 | 2021-08-23 09:14:20.251 HD Server | HD Request #5 | Socket: 9 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-08-23 07:10:31 | ClientReqID: 5 | Username: Kza57SC. | Thread:3496 | 2021-08-23 09:14:20.252 HD Server | HD Request | Socket: 9 | Symbol: NQU1.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 458 | ClientReqID: 5 | Username: Kza57SC. | Thread:3496 | 2021-08-23 09:14:20.254 HD Server | Thread:3496 (9) | Socket gracefully closed by remote side. | 2021-08-23 09:14:20.255 HD Server | Thread:3496 (9) | CloseSocket call. | 2021-08-23 09:14:20.255 HD Server | Thread:3496 (0) | CloseSocket call. | 2021-08-23 09:14:20.256 HD Server | Thread:3496 (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-23 09:14:20.256 HD Server | Thread:3496 (9) | Closed. | 2021-08-23 09:14:20.256 HD Server | Thread:3496 (0) | CloseSocket call. | 2021-08-23 09:14:20.256 DTC client #4. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol ESU1.CME | 2021-08-23 09:14:20.326 DTC client #4. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol NQU1.CME | 2021-08-23 09:14:20.326 HD Server | Server thread ending. Closing socket. | Username: Kza57SC. | Thread:3496 | 2021-08-23 09:14:20.643 HD Server Manager | Current server count=0 | 2021-08-23 09:14:20.643 |
[2021-08-23 07:49:46] |
Kza57 - Posts: 13 |
So, I'm now on 2293 and it works...
[2021-08-23 09:17:39] |
We will need to ask Rithmic about this. We will do that now. These are the relevant messages: Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-08-23 09:11:05.012
Rithmic Direct - DTC | Sending logon request message. | 2021-08-23 09:11:05.012 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-08-23 09:11:05.357 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-24 11:27:10] |
The problem should be resolved according to Rithmic.
[2021-08-24 12:37:05] |
Kza57 - Posts: 13 |
Thank you !
[2021-08-24 15:10:02] |
fcpauldiaz - Posts: 18 |
I can connect now but I cannot remove the Simulation mode, is someone having this issue as well?
[2021-08-24 16:04:26] |
So you cannot remove the checkmark from Trade >> Trade Simulation Mode On?
[2021-08-24 16:19:02] |
I had to remove my Rithmic credentials and re-add them to turn off the Trade Simulation Mode, now it is properly working. Thanks!
