Date/Time: Tue, 26 Nov 2024 00:53:01 +0000
Positions Not Showing up on Trade Window when Using IB
View Count: 994
[2014-03-21 16:54:41] |
kleros - Posts: 21 |
I am using IB as trade service with SC data. I have been successful placing orders in SC using the DOM but my position shows "flat" immediately the order is filled. I can then see the attached orders on the SC DOM but there is no indication where the entry was located. How do I fix this issue? Chris |
[2014-03-21 17:01:59] |
FYI, I am using a financial advisor account with IB.
[2014-03-21 18:01:38] |
We are working on documentation for this now.
[2014-03-21 18:33:26] |
Refer to the documentation for this here: https://www.sierrachart.com/index.php?l=doc/helpdetails80.html#UsingOrderFillCalculatedPosition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
