Date/Time: Sun, 20 Sep 2026 11:58:10 +0000
Daily Bars on Stock Chart
View Count: 872
[2021-08-21 15:49:51]
wingz - Posts: 121
Is there a way to set the bars, on a daily stock chart, to print red or green, based on the previous days CLOSE? Red if the CLOSE is below the previous day's close and green if the CLOSE is above the previous day's close.
[2021-08-23 15:02:30]
John - SC Support - Posts: 47939
You would use the Color Bar Based on Alert Condition to do this. Refer to the following:
[2021-08-24 06:59:20]
You will want to use this setting for this:
Graphics Settings: Up/Down Coloring for OHLC Bars Based on Previous and Current Close
