Date/Time: Fri, 28 Feb 2025 18:15:58 +0000
Replay Large Volume Indicator does not work
View Count: 672
[2021-08-20 08:09:11] |
User262794 - Posts: 6 |
Hello SC, I'm using Large Volume Indicator and it works great on live feed. But doesn't work during Standard Replay. My SC version is 2285. Thank you! |
[2021-08-20 09:41:52] |
That study requires tick by tick data. Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration We see you are using CQG. For complete tick by tick data you must use the Denali Exchange Data Feed when using CQG. Documentation and instructions: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-20 15:09:10] |
Another thing you can do for replays is use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service This service provides tick by tick data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-20 15:09:27
[2021-08-31 17:20:00] |
Hello SC, I am still facing issue with Large Vol Indicator. Intraday Data Storage Unit: 1 tick. During live session is everything OK and Large Vol Indicator works great. But during replay (standard) shows nothing, please find the screenshot. Thank you! |
Private File |
[2021-08-31 17:54:47] |
John - SC Support - Posts: 38280 |
We just ran a quick test to ensure there is nothing obviously wrong with the Large Volume Trade Indicator during a Replay, and we got exactly what we expected, the data showed up as the replay was running. Can you give us a screenshot of that same chart for the same time period when the Replay is NOT running, so we can see what you are seeing before the replay. Also, at what point did you start the replay? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-31 18:05:19] |
Thank you for quick response. I am uploading: LargeVolIndi_NO_Replay = just after put study to the chart LargeVolIndi_DURING_Replay = replay is running LargeVolIndi_BEFORE_Replay = after Go to Date-Time (beginning of US session) Hope it helps. Thank you! Date Time Of Last Edit: 2021-08-31 18:10:32
Private File Private File Private File |
[2021-08-31 18:30:22] |
You need to use the Denali Exchange Data Feed for complete tick by tick data: Denali Exchange Data Feed We do not provide technical help for CQG data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
