Date/Time: Fri, 28 Feb 2025 13:47:45 +0000
Unable to CONNECT
View Count: 578
[2021-08-20 01:58:11]
User834423 - Posts: 1
Status window yellow CONNECTING. Have selected Disconnect and then Connect to Data Feed.
No luck with Charts or Dome
Updated to latest version, I can see charts but data stopped 90 minutes ago.
Internet is fine, everything works but SC
Any ideas? Nothing changed I am aware of, it just stopped
Thank you
[2021-08-20 06:52:39]
We see you are trying to connect to Transact. Transact must be having a problem.
Contact Transact about this.
Also be aware of the Sierra Chart Order Routing service:
Sierra Chart / Trading Technologies Futures Order Routing Service
Something that you should consider moving to, at some point in the future. It provides very highly reliable connectivity.
