Date/Time: Fri, 28 Feb 2025 13:30:44 +0000
ANOMALY 1 MIN CHART
View Count: 481
[2021-08-19 16:31:54] |
User993113 - Posts: 74 |
Hello support, I have an annoying problem for a few days with the 1 min chart on stocks. My setting is 1 min chart (day-min-sec: 0-1-0), but most tickers start the minute bar with a second delay. In other words, instead of having the bars 9.30-9.31-9.32, my bars are 9.30.01-9.31.01-9.32.01 etc ... This problem occurs exclusively on the 1 min charts, instead all the other settings (2,3,5 min etc) work correctly. Can you help me? |
[2021-08-19 17:31:01] |
John - SC Support - Posts: 38259 |
Make sure your Session Times are set correctly. And ensure that if you are using the Evening Session, that you are not overlapping the Regular hours with the Evening Session. Refer to the information here: Chart Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
