Date/Time: Fri, 28 Feb 2025 13:30:46 +0000
Live Data
View Count: 458
[2021-08-19 16:29:54] |
ark03 - Posts: 1 |
I've subscribed for Denali Feed with Package 11. It appears that I need to connect to live trading account (or validate AMP account) for live data. I used to get atleast delayed data. Now, I do not even see delayed data after subscribing to Denali feed. Can you advise? I'm trying to figure out the trading account requirement in the meantime. |
[2021-08-19 16:55:25] |
John - SC Support - Posts: 38259 |
To get the Real-Time Denali data for the CME Group, you need to go through the Setup Instructions here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you are wanting data for EUREX or CFE, then those instructions are on the same page, just scroll to the top and select the link for the appropriate instructions. For the CME Group data, you need to be aware of the CME Group requirement that you have a live, funded, futures trading account in order to qualify for the non-professional exchange fees. For more information, refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Since you have an account with AMP, you would just need to connect your Sierra Chart to that account. For us to point you to the proper documentation, we need to know if you are using Rithmic, or CQG for your order routing with AMP. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
