Date/Time: Fri, 28 Feb 2025 13:29:55 +0000
SUBSCRIPTION TO VIX
View Count: 903
[2021-08-19 13:27:11]
Samuel David - Posts: 22
Dear Support,
Kindly advise on how to subscribe and get VIX data
Thanks, Samuel
[2021-08-19 15:45:07]
John - SC Support - Posts: 38259
It depends on which VIX you are wanting. Do you want the VIX Index or the VIX Futures?
[2021-08-19 17:30:11]
I would like the CBOE VIX Index for S&P
[2021-08-19 17:51:12]
That data comes from our Sierra Chart Exchange Data Feed and requires the CBOE Indices exchange to be activated. Refer to the Setup Instructions here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
[2021-08-19 19:19:52]
Ok. Thanks
[2021-08-19 20:00:26]
Managed to subscribe, went through the drill, but still not able to see CBOE. Kindly guide and assist.
[2021-08-19 20:34:23]
Go to File >> Find Symbol and under Indexes (Real-Time), you will find the entry for $VIX. Select that, then select the button for either Open Historical Chart or Open Intraday Chart depending on which one you want.
[2021-08-21 09:44:11]
Hi John,
Thanks. Managed
[2021-08-23 13:18:31]
I subscribed to SC Real Data on Thursday 19th inorder to get VIX, but it seems to be extremely slow and affecting my charts. How can i revert back to my previous connections?
Appreciate your feedback.
[2021-08-23 14:00:08]
Do you mean the updating of the $VIX chart is slow?
Or what exactly is the problem.
If you are experience any performance issues, refer to help topic 30:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
Date Time Of Last Edit: 2021-08-23 14:00:23
