Date/Time: Mon, 20 Jan 2025 05:23:04 +0000
[Programming Help] - Market Depth historical Graph
View Count: 1165
[2021-08-19 12:04:33]
User260950 - Posts: 10
Hi
Could you please help me with the following issues:
A)
Running study with Market Depth historical Graph:
Picture 1: ZBU21 CBOT // correct
http://www.sierrachart.com/image.php?Image=1629373146402.png
Picture 2: Binance / ADAUSDT: does not run correctly ; // applies to all Binance derivatives, not only ADAUSDT
http://www.sierrachart.com/image.php?Image=16293730694.png
B)
How can I get ALL values from the Market Depth historical Graph (= values, which are shown in Picture 1) into a spreadsheet – The spreadsheet only shows the volume values inside the bars, but no Heatmap values like shown in Picture 1
Thanks!
PS: Topic A)
see also:
[2021-07-13 15:21:36]#5
John - SC Support [Direct Messages] - Posts: 9996 | Ending Date: 2022-04-04
[2021-08-19 12:54:45]
First thing we want you to do, is update Sierra Chart, to the current version. Instructions:
[2021-08-19 19:30:56]
to A) update done / it works / thanks
to B) still the same as described above - is there a way to get this data into a spreadsheet?
