Date/Time: Fri, 28 Feb 2025 13:42:40 +0000
Forward projection bars
View Count: 869
[2021-08-19 11:54:25]
User736044 - Posts: 51
In the study forward projection bars I'd like to forward for example 5 bars but i pick to have a displacement of 10 bars forward to give some distance from the other ones. When it starts it's all good but as the bars print the forwarded bars keep displaying more than 5 unless i go back to the study and hit apply
Thank You,
Date Time Of Last Edit: 2021-08-19 11:58:12
[2021-08-19 15:11:15]
John - SC Support - Posts: 38259
We have added a new Input for the Forward Projection Bars called Delete Prior Bars. When set to Yes, bars that had been drawn prior to the Number of Bars to Project Forward are removed as new bars are added.
This change will be in the next Pre-Release (v 2299). When available you can update using the Fast Update option:
[2021-08-19 17:20:55]
Great, Thank You!
