Date/Time: Mon, 14 Sep 2026 04:33:58 +0000
My TPO chart is showing a 20 tick different price to my candle stick chart can you help me
View Count: 869
| [2021-08-19 06:48:14] |
| User324634 - Posts: 6 |
My TPO chart is showing a 20 tick different price to my candle stick chart can you help me please.
| Attachment Deleted. |
| [2021-08-19 14:17:47] |
| John - SC Support - Posts: 47854 |
From what you are showing, we assume that you are asking why the Current Price is different in the two charts, given that you were running a Replay and paused the replay. Therefore, you would think that the prices in the two charts would be the same. If this is what your question is about, then the main item to look at is whether the charts both have enough loaded data such that wherever you started the replay was available in both charts. We also noticed that one chart is Back-Adjusted the other is not. This could also be part of the issue, if you are far enough back to not be on the current contract. But, also look over the following section on synchronization of the charts: Replaying Charts: Automatic Skipping of Periods Where There Is No Trading and Synchronization For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-08-20 07:52:09] |
Also one chart is paused and the other is not during the replay.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-20 07:52:17
