Date/Time: Fri, 28 Feb 2025 13:26:06 +0000
Trouble connecting to trans act data through Infinity Futures
View Count: 366
[2021-08-18 16:07:16] |
User343047 - Posts: 16 |
I can not connect data to my charts through Infinity. i tried to copy log as per instruction on self help but i cant do it thank you |
[2021-08-18 17:00:59] |
John - SC Support - Posts: 38259 |
Are you trying to access data from the EUREX? Are you having problems with other exchanges (such as CME Group)?
[2021-08-19 04:31:20] |
Sierra_Chart Engineering - Posts: 18600 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
