Date/Time: Fri, 28 Feb 2025 08:59:21 +0000
Strange doted line
View Count: 407
[2021-08-18 15:04:28]
User837393 - Posts: 143
What is that weird doted line? It only appears only when I set the scale setting to X and Y constant relationship.
http://www.sierrachart.com/image.php?Image=1629298955591.png
Best regards.
[2021-08-18 15:16:45]
John - SC Support - Posts: 38259
It is not anything that is specifically related to that Scale Setting, so there must be a study or a drawing that is just showing up under those circumstances for some reason. But why it is across the DOM, in particular, is very odd.
Get us a copy of that chart (and ensure the copy has the same issue) into a Chartbook of it's own and attach that chartbook for us to take a look at. Follow these instructions to do this:
[2021-08-18 15:19:54]
Solved ....
Under Graphic Settings - Chart
Chart DOM Recenter line was enabled .... Don't knwo why.
I disabled it.
Best regards,
[2021-08-18 15:45:04]
Very good.
