Date/Time: Fri, 28 Feb 2025 08:58:46 +0000
Data missing
View Count: 497
[2021-08-18 04:26:32] |
mulayam singh yadav - Posts: 9 |
Hi Whenever I log in I see no numbers on the chart and have to wait to get the new data printed on the chart for few minutes and historical data is still missing I have attached a picture so you can take a look and it's a points and figure chart.
Date Time Of Last Edit: 2021-08-18 04:28:32
[2021-08-18 08:37:57] |
You need to use the Denali Exchange Data Feed for the proper data for Sierra Chart. Refer to: Denali Exchange Data Feed Set up instructions are on that page. Let us know if you need more help. You will want to tell your broker, to cancel all CME exchange fees, so you just pay those through us and not through them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-18 08:38:05
