Date/Time: Fri, 28 Feb 2025 09:08:21 +0000
Does Sierra charts have a template for multiple fixed charts in one chartbook pane?
View Count: 592
[2021-08-17 23:03:01] |
Dan the Man - Posts: 92 |
Hi, I bought a 32:9 49" Samsung Monitor. Does Sierra charts have a template for multiple fixed charts in one chartbook pane? I'm always having to adjust the charts edges. I attached a screen shot to show what I'm trying to do. Kind Regards, Daniel |
[2021-08-18 10:04:26] |
Sierra_Chart Engineering - Posts: 18600 |
Have a look at the Tile as Grid functionality: Window, CB and CW Menus: Tile as Grid - Horizontally (Window) Those commands are also configurable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
