Date/Time: Wed, 09 Sep 2026 23:31:15 +0000
Study Settings
View Count: 727
[2021-08-17 20:20:03]
User377189 - Posts: 216
Under study settings changing input values for
Horizontal Position from Left
and
Vertical Position from bottom
for following studies does not changes the position of the studies on the chart:
1) Rollover Date Display
2) Text display For study from chart
3) Countdown timer
Also for countdown timer study i changed default settings for Input value -->
Use current price for vertical position
from NO to YES. Then again changed from YES to NO and now the study is hidden and did not return to original position based on prior input value (screenshot attached)
imageCountdown timer.png / V - Attached On 2021-08-17 20:17:58 UTC - Size: 46.3 KB - 234 views
[2021-08-17 20:42:42]
John - SC Support - Posts: 47822
What you are seeing is correct. Those are the "Initial Positions" for the drawing. In other words, prior to the information being drawn to the screen, that is where it will end up. But, once it is on the screen, you then have to move those drawings as you would other "drawings", by right-clicking on the item and then selecting Move Drawing. Refer to the following information on this:
Countdown Timer: Moving Countdown Timer
