Date/Time: Tue, 15 Sep 2026 17:52:54 +0000
update chart drawings to current symbol
View Count: 2622
| [2014-03-21 07:10:56] |
| AKR - Posts: 542 |
is it possible to undo that? so I see this right that the function copies 1:1 the drawings to the next symbol, but it does not back adjust them, does it. This would be a pretty cool feature, if SC would do the same way as with the old prices. Am I right that SC asks for roll over on the day of expiration of old contracts. not on next day. As I am asked today for EUREX rollover, though the March contracts still trade until 12-13h? How can I stop being asked to roll over? rgrds Date Time Of Last Edit: 2014-03-21 07:26:23
| [2014-03-21 18:19:26] |
No. Unless you close the Chartbook without saving it and then reopen it. Refer to the documentation here: https://www.sierrachart.com/index.php?l=doc/doc_ChartMenu.html#UpdateChartDrawingsCurrentSymbol You can adjust the Rollover settings in the Global Symbol Settings: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-21 19:13:09
| [2014-03-24 07:33:06] |
| AKR - Posts: 542 |
any chance to have a setting, that adjusts the drawings for the same number of points, as the price line/bar? Because this is really a bit of a nightmare. I have quite a lot ext rectangles to mark my important price levels and now after the roll over they seem to be "anywhere"... this more or less means I can delete all drawings and make them new. Or am I missing something?
| [2014-06-05 12:07:46] |
| AKR - Posts: 542 |
as rollover before -- once again that question if the drawings could not be adjusted on rollover to next contract. I like the "update chart drawings to current symbol" very much, but does it make sense at all, if the drawings are not adjusted to the new price levels? |
| [2014-06-06 05:49:21] |
| AKR - Posts: 542 |
I would like to stress this once again, as I really beleive it is important. Please have a look at the chart uploaded http://www.sierrachart.com/image.php?l=1402033550731.png This is now the drawings from old FGBL contract in new one. You see this does not make sense. So the functionality is great, but what does it help me if the drawings are "anywhere" on the new symbol chart?? Then I can imediately delete the drawings and make everything new again .... and as I came to know you guys I believe you want your SW and its functions to support the user. one more question: does the function only copy the drawings from the most recent (past) contract or from all contracts of the same symbol. Date Time Of Last Edit: 2014-06-06 05:53:11
| [2014-09-08 05:32:57] |
| AKR - Posts: 542 |
helo SC support, roll over time again so once again I would like to ask for this functionality. it really is anoying rolling over to new symbol and loosing all drawings by this. rgrds |
| [2014-09-08 20:39:40] |
You can adjust chart drawings through Tools >> Manage Chart Drawings Window. Select the drawings and press the Adjust button.
| [2014-09-11 06:01:29] |
| AKR - Posts: 542 |
OK, but if I have some 30 drawings it would be nice having a function moving all with one operation. And it would be good to automatically somewhere see the backadjustment value. Or do I have that somewhere? cheers |
| [2014-09-11 06:31:09] |
You can select all 30 drawings by holding the control key and selecting each of them in the Manage Chart Drawings Window. Once the adjustment is made, there is no remembering of what that value was. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
