Date/Time: Fri, 28 Feb 2025 13:36:08 +0000
Trade Quantity Window changed - tedious
View Count: 375
[2021-08-17 14:57:41]
TropicalTrader - Posts: 45
Hi, somehow my trade quantity window changed to the attached image, now its slow and tedious to change the quantity, how do I fix this?
Date Time Of Last Edit: 2021-08-17 14:57:54
imageexample.jpg / V - Attached On 2021-08-17 14:55:07 UTC - Size: 18.21 KB - 153 views
[2021-08-17 15:05:27]
John - SC Support - Posts: 38259
What you are seeing is one of our new windows. There are a number of places where these changes have already occurred, mostly in the Settings areas, but also for that Quantity change. There is no "fix" for this.
But, if you let us know how you want to interact with the window to make your change faster, then we can see if there are changes we can make to the window to accomodate.
[2021-08-17 15:23:43]
It's too slow for me compared to how it was before. It takes a few seconds to make the change now. 5 clicks compared to 3 before plus the window is small and it takes time to look and find the right place to click..
I would downgrade but I need the new version for a special levels indicator I have..
[2021-08-17 16:53:02]
Update, I was able to find an older version for my indicator and downgrade. Imo, the old trade quantity window is way better.
[2021-08-19 20:27:32]
The window is resizable. We can make sure the size is remembered per chart.
