Date/Time: Fri, 28 Feb 2025 18:12:39 +0000
Unhandled Exception - Moving Stops/Targets
View Count: 590
[2021-08-17 14:36:13]
SpearChucker - Posts: 104
Moving stops and targets on the DOM I get this error msg. Stops and targets appear to have moved to where I want them, though.
imageExcept.jpg / V - Attached On 2021-08-17 14:34:52 UTC - Size: 44.37 KB - 173 views
[2021-08-17 15:00:17]
Disregard the prior message. It is not correct.
We think this issue is related to a stack overflow. Although that definitively should not be occurring and we are unable to reproduce but we will test again.
We have reduced the stack space involved with order modifications. We will be putting out a new release, in about an hour.
You will want to update at that time to the latest prerelease:
Also this is a serious issue. When you get those exceptions you need to restart Sierra Chart.
Date Time Of Last Edit: 2021-08-17 15:00:27
[2021-08-17 19:11:18]
We did not yet get the new release out. It will be sometime after the close today.
[2021-08-18 08:45:07]
Update to the latest prerelease and see if you still have the issue. Instructions:
We want to make it clear, this is not a problem within Sierra Chart code. There is some other cause but we are trying things that may work around it based upon some reasonable assumptions.
And we have never been able to reproduce this either.
Date Time Of Last Edit: 2021-08-19 06:26:16
[2021-08-27 14:15:12]
Happened again.
GCZ21-GCG22.GC.FUT_SPREAD.COMEX[M] #1 | Caught an unhandled exception in c_Chart::OnLButtonUp. | 2021-08-27 10:08:01.478 *
I've updated to version 2299. I don't know what version the prerelease was at the time of your response in #5 on 8/18. Do I still need to update to the current prerelease (2301)?
[2021-08-27 15:14:53]
John - SC Support - Posts: 38280
Just to be absolutely certain that you have the update where we made some changes to help the situation, update to the current Pre-Release (v 2301 as of this writing).
Then let us know if you continue to have the problem or not.
[2021-08-27 16:29:03]
We are going to do additional work on this issue today. We are going to add some additional logging to further isolate the problem. And also make some additional changes to reduce the amount of stack space used during order modifications which is very very minimal already, not even close to a problem but we will still try to do all we can.
Date Time Of Last Edit: 2021-08-27 16:29:27
[2021-08-30 19:22:23]
Test prerelease 2302. Instructions:
