Date/Time: Fri, 28 Feb 2025 10:20:09 +0000
DENALI EXCHANGE DATA FEED
View Count: 394
[2021-08-17 12:41:49] |
User363775 - Posts: 25 |
Once I sign up for the Denali exchange on the 1st of Next month, my current Data feed for CME and the rest of them will be transferred automatically to the new Denali data feed and I will get a pro rata refund on the days not used? What about Eurex futures, does that mean if I need that as well I need to stay on the current data feed and change amongst denali and my current data feed in Sierrachart when I switch between Eurex to CME? |
[2021-08-17 12:49:43] |
and I will get a pro rata refund on the days not used? We do not know what you mean by this. There is no refund.What about Eurex futures, does that mean if I need that as well I need to stay on the current data feed and change amongst denali and my current data feed in Sierrachart when I switch between Eurex to CME?
The Denali data feed does provide EUREX data. We are not understanding this question either.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-17 12:49:54
