Date/Time: Fri, 28 Feb 2025 09:56:17 +0000
Error downloading Data
View Count: 473
[2021-08-17 11:20:58]
artmaan - Posts: 26
Hello SC Support,
i wanted to make a backup of the SC folder, i noticed that i had alot of data for sysmbols which i didnt need, so i deleted them and copied the SC folder.
now if i open SC, i do get an error for downloading or writing data.
can you tell me please how to solve this or whts causing this?
i have copied the message log and the error.
thank you
Created the DTC Protocol server. | 2021-08-17 13:05:26.337
DTC Protocol Server listening on port 11099. | 2021-08-17 13:05:26.342
Reading Internal Order ID file. | 2021-08-17 13:05:26.342
Reading Trade Orders file. | 2021-08-17 13:05:26.422
Reading Trade Positions file. | 2021-08-17 13:05:26.423
Reading Trade Account Data files. | 2021-08-17 13:05:26.423
UDPListener (1536). Port 22904 | Listening on UDP port 22904. | 2021-08-17 13:05:26.450
Software version: 2296 64-bit | 2021-08-17 13:05:26.450
Primary Thread ID: 2624 | 2021-08-17 13:05:26.450
Usage end date: 2021-10-14 | 2021-08-17 13:05:26.450
Enabled for: Sierra Chart Historical Data Service. | 2021-08-17 13:05:26.450
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-08-17 13:05:26.450
Enabled for: Delayed Denali Exchange Data Feed. | 2021-08-17 13:05:26.450
Enabled for exchange2: CME (Trading Account Required) | 2021-08-17 13:05:26.450
Enabled for exchange2: CBOT (Trading Account Required) | 2021-08-17 13:05:26.450
Enabled for exchange2: COMEX (Trading Account Required) | 2021-08-17 13:05:26.450
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-08-17 13:05:26.450
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-08-17 13:05:26.450
Current selected Data/Trading service: SC Data - All Services | 2021-08-17 13:05:26.450
Custom symbol settings values: disabled | 2021-08-17 13:05:26.450
Chart Update Interval: 500 | 2021-08-17 13:05:26.450
Intraday Data Storage Time Unit: 0 | 2021-08-17 13:05:26.450
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2021-08-17 13:05:26.450
2021-08-17 11:05:26 Local computer time in UTC | 2021-08-17 13:05:26.450
2021-08-17 13:05:26 Local computer time in SC Time Zone | 2021-08-17 13:05:26.450
2021-08-17 11:05:25 Server time in UTC | 2021-08-17 13:05:26.450
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-08-17 13:05:26.450
Program path: C:\SierraChart\ | 2021-08-17 13:05:26.450
Data Files path: C:\SierraChart\Data\ | 2021-08-17 13:05:26.450
OS Version Number: 10.0 | 2021-08-17 13:05:26.450
Locale Setting: C | 2021-08-17 13:05:26.450
DLLs: ajp_study_position_64.dll, ECIVwapV1.4.dll, ETFISv3.dll, ETFISv3_64.dll, ETOFSv3.dll, ETOFSv3_64.dll, GomVelocity (1).dll, GomVelocity.dll, OFA Bars (by Zdislav)_2151_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, zyp sierra free 2020_2151_64.dll, zyp sierra free 2021_2151_64.dll, zyp sierra free_2151_64.dll | 2021-08-17 13:05:26.451
Allowed protected custom studies: zyp_download_free | 2021-08-17 13:05:26.451
Created the DTC Protocol historical data server. | 2021-08-17 13:05:26.470
HD Server Manager | Listening on port 11098. | 2021-08-17 13:05:26.473
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2021-08-17 13:05:26.473
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-08-17 13:05:26.515
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-08-17 13:05:26.569
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-08-17 13:05:26.569
Received 5 login tokens. | 2021-08-17 13:05:26.684
Symbol settings MD5 received. Request ID: 1. | 2021-08-17 13:05:27.135
Symbol settings are up-to-date for scdataallservices. | 2021-08-17 13:05:27.135
Files to Open on Startup | Opening file: BTC.Cht | 2021-08-17 13:05:30.809
Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ff925240000 | 2021-08-17 13:05:30.820
Chart (XBTUSD-BMEX) | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:30.973
XBTUSD-BMEX 60 Min #1 | Reloading chart. | 2021-08-17 13:05:30.974
XBTUSD-BMEX 60 Min #1 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:30.977
Unknown Intraday file type. Header error. C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:30.979
Chart (XBTUSD-BMEX) | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.157
XBTUSD-BMEX 240 Min #2 | Reloading chart. | 2021-08-17 13:05:31.157
XBTUSD-BMEX 240 Min #2 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.161
Unknown Intraday file type. Header error. C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.164
Chart (XBTUSD-BMEX) | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.331
XBTUSD-BMEX 60 Min #3 | Reloading chart. | 2021-08-17 13:05:31.331
XBTUSD-BMEX 60 Min #3 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.335
Unknown Intraday file type. Header error. C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.336
Chart (XBTUSD-BMEX) | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.505
XBTUSD-BMEX 2000 Trades #8 | Reloading chart. | 2021-08-17 13:05:31.506
XBTUSD-BMEX 2000 Trades #8 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.509
Unknown Intraday file type. Header error. C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.511
Chart (XBTUSD-BMEX) | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.665
XBTUSD-BMEX 5000 Trades #5 | Reloading chart. | 2021-08-17 13:05:31.666
XBTUSD-BMEX 5000 Trades #5 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.670
Unknown Intraday file type. Header error. C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.672
Chart (XBTUSD-BMEX) | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.806
XBTUSD-BMEX 10000 Trades #6 | Reloading chart. | 2021-08-17 13:05:31.807
XBTUSD-BMEX 10000 Trades #6 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.811
Unknown Intraday file type. Header error. C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.813
Chart (XBTUSD-BMEX) | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.977
XBTUSD-BMEX 120 Min #7 | Reloading chart. | 2021-08-17 13:05:31.978
XBTUSD-BMEX 120 Min #7 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.982
Unknown Intraday file type. Header error. C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:31.984
Chart (XBTUSD-BMEX) | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:32.178
XBTUSD-BMEX 10000 Trades #4 | Reloading chart. | 2021-08-17 13:05:32.179
XBTUSD-BMEX 10000 Trades #4 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:32.183
Unknown Intraday file type. Header error. C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:32.184
Using Bid/Ask average for last trade price for AUDJPY | 2021-08-17 13:05:32.218
Using Bid/Ask average for last trade price for AUDNZD | 2021-08-17 13:05:32.218
Using Bid/Ask average for last trade price for AUDUSD | 2021-08-17 13:05:32.218
Using Bid/Ask average for last trade price for Bund | 2021-08-17 13:05:32.219
Using Bid/Ask average for last trade price for CADJPY | 2021-08-17 13:05:32.219
Using Bid/Ask average for last trade price for CHN50 | 2021-08-17 13:05:32.220
Using Bid/Ask average for last trade price for Copper | 2021-08-17 13:05:32.220
Using Bid/Ask average for last trade price for CORNF | 2021-08-17 13:05:32.220
Using Bid/Ask average for last trade price for EURAUD | 2021-08-17 13:05:32.222
Using Bid/Ask average for last trade price for EURCAD | 2021-08-17 13:05:32.222
Using Bid/Ask average for last trade price for EURCHF | 2021-08-17 13:05:32.222
Using Bid/Ask average for last trade price for EURGBP | 2021-08-17 13:05:32.222
Using Bid/Ask average for last trade price for EURJPY | 2021-08-17 13:05:32.222
Using Bid/Ask average for last trade price for EURNZD | 2021-08-17 13:05:32.222
Using Bid/Ask average for last trade price for EURTRY | 2021-08-17 13:05:32.222
Using Bid/Ask average for last trade price for EURUSD | 2021-08-17 13:05:32.223
Using Bid/Ask average for last trade price for GBPAUD | 2021-08-17 13:05:32.223
Using Bid/Ask average for last trade price for GBPCAD | 2021-08-17 13:05:32.223
Using Bid/Ask average for last trade price for GBPCHF | 2021-08-17 13:05:32.223
Using Bid/Ask average for last trade price for GBPJPY | 2021-08-17 13:05:32.223
Using Bid/Ask average for last trade price for GBPNZD | 2021-08-17 13:05:32.223
Using Bid/Ask average for last trade price for GBPUSD | 2021-08-17 13:05:32.224
Using Bid/Ask average for last trade price for GER30 | 2021-08-17 13:05:32.224
Using Bid/Ask average for last trade price for NAS100 | 2021-08-17 13:05:32.224
Using Bid/Ask average for last trade price for NGAS | 2021-08-17 13:05:32.224
Using Bid/Ask average for last trade price for NZDUSD | 2021-08-17 13:05:32.224
Using Bid/Ask average for last trade price for SOYF | 2021-08-17 13:05:32.225
Using Bid/Ask average for last trade price for SPX500 | 2021-08-17 13:05:32.225
Using Bid/Ask average for last trade price for US30 | 2021-08-17 13:05:32.226
Using Bid/Ask average for last trade price for USDCHF | 2021-08-17 13:05:32.226
Using Bid/Ask average for last trade price for USDJPY | 2021-08-17 13:05:32.226
Using Bid/Ask average for last trade price for USOil | 2021-08-17 13:05:32.226
Using Bid/Ask average for last trade price for WHEATF | 2021-08-17 13:05:32.227
Using Bid/Ask average for last trade price for XAGUSD | 2021-08-17 13:05:32.227
Using Bid/Ask average for last trade price for XAUUSD | 2021-08-17 13:05:32.227
Files to Open on Startup | Opening file: NQ.Cht | 2021-08-17 13:05:32.235
FDAXU21-EUREX/FDXMU21-EUREX [CBV] 1000 Trades #1 | Reloading chart. | 2021-08-17 13:05:32.302
FDAXU21-EUREX/FDXMU21-EUREX [CBV] 1000 Trades #1 | Performing historical Daily data download for symbol FDAXU21-EUREX starting at last date in file. | 2021-08-17 13:05:32.304
Starting DelayedDownloadMonitoringTimer | 2021-08-17 13:05:32.304
Starting HDTimeoutTimer | 2021-08-17 13:05:32.304
Added historical Daily data request for FDAXU21-EUREX to the queue. | 2021-08-17 13:05:32.304
Triggering next historical data download in queue. | 2021-08-17 13:05:32.304
FDAXU21-EUREX/FDXMU21-EUREX [CBV] 1000 Trades #1 | Waiting for historical downloads to complete with the IDs: 1, | 2021-08-17 13:05:32.315
FDAXM21-EUREX Daily #2 | Reloading chart. | 2021-08-17 13:05:32.335
Chart (MNQU21-CME) | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:32.593
MNQU21-CME/FDXMU21-EUREX [CBV] 500 Volume #3 | Reloading chart. | 2021-08-17 13:05:32.595
Error opening the file to check the date-time range. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. | 2021-08-17 13:05:32.596
SC Data - All Services | Connected to server complete. | 2021-08-17 13:05:32.596
Triggering next historical data download in queue. | 2021-08-17 13:05:32.597
Starting DelayedDownloadMonitoringTimer | 2021-08-17 13:05:32.615
Starting HDTimeoutTimer | 2021-08-17 13:05:32.615
Added historical Intraday data request for MNQU21-CME to the queue. | 2021-08-17 13:05:32.615
MNQU21-CME/FDXMU21-EUREX [CBV] 500 Volume #3 | Performing historical Daily data download for symbol MNQU21-CME starting at last date in file. | 2021-08-17 13:05:32.616
Added historical Daily data request for MNQU21-CME to the queue. | 2021-08-17 13:05:32.617
MNQU21-CME/FDXMU21-EUREX [CBV] 500 Volume #3 | Waiting for historical downloads to complete with the IDs: 2, 3, | 2021-08-17 13:05:32.629
Chart (MNQU21-CME) | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:32.878
MNQU21-CME [CBV] 1500 Trades #4 | Reloading chart. | 2021-08-17 13:05:32.879
MNQU21-CME [CBV] 1500 Trades #4 | Waiting for historical downloads to complete with the IDs: 2, 3, | 2021-08-17 13:05:32.892
Chart (MNQU21-CME) | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:33.130
MNQU21-CME [CBV] 5000 Trades #5 | Reloading chart. | 2021-08-17 13:05:33.131
Error opening the file to check the date-time range. Header check failed when opening the file C:\SierraChart\Data\MNQM21-CME.scid for reading. Error: Unknown Intraday file type. Header error. | 2021-08-17 13:05:33.132
Added historical Intraday data request for MNQM21-CME to the queue. | 2021-08-17 13:05:33.132
MNQU21-CME [CBV] 5000 Trades #5 | Waiting for historical downloads to complete with the IDs: 2, 3, 4, | 2021-08-17 13:05:33.165
Chart (NQU21-CME) | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\NQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\NQU21-CME.scid | 2021-08-17 13:05:33.353
NQU21-CME [CBV] 500 Trades #6 | Reloading chart. | 2021-08-17 13:05:33.353
Error opening the file to check the date-time range. Header check failed when opening the file C:\SierraChart\Data\NQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. | 2021-08-17 13:05:33.353
Added historical Intraday data request for NQU21-CME to the queue. | 2021-08-17 13:05:33.354
NQU21-CME [CBV] 500 Trades #6 | Performing historical Daily data download for symbol NQU21-CME starting at last date in file. | 2021-08-17 13:05:33.355
Added historical Daily data request for NQU21-CME to the queue. | 2021-08-17 13:05:33.355
NQU21-CME [CBV] 500 Trades #6 | Waiting for historical downloads to complete with the IDs: 5, 6, | 2021-08-17 13:05:33.367
Chart (MNQU21-CME) | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:33.560
MNQU21-CME [CBV] 500 Trades #8 | Reloading chart. | 2021-08-17 13:05:33.561
MNQU21-CME [CBV] 500 Trades #8 | Waiting for historical downloads to complete with the IDs: 2, 3, | 2021-08-17 13:05:33.574
XBTUSD-BMEX 60 Min #1 | Error opening or reading chart data file. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:33.601
XBTUSD-BMEX 240 Min #2 | Error opening or reading chart data file. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:33.610
XBTUSD-BMEX 60 Min #3 | Error opening or reading chart data file. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:33.618
XBTUSD-BMEX 2000 Trades #8 | Error opening or reading chart data file. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:33.619
XBTUSD-BMEX 5000 Trades #5 | Error opening or reading chart data file. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:33.620
XBTUSD-BMEX 10000 Trades #6 | Error opening or reading chart data file. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:33.621
XBTUSD-BMEX 120 Min #7 | Error opening or reading chart data file. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:33.622
XBTUSD-BMEX 10000 Trades #4 | Error opening or reading chart data file. File: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:33.623
Mapping FDAXU21-EUREX to FDAX202109_FUT_EUREX. Service code: eurex | 2021-08-17 13:05:33.623
HD Request # 1 | Downloading Historical Daily chart data for FDAXU21-EUREX. Starting date: 2021-08-12. Service: eurex | 2021-08-17 13:05:33.626
No download requests in the queue to start downloads for. | 2021-08-17 13:05:33.633
Mapping MNQU21-CME to MNQU21. Service code: cme | 2021-08-17 13:05:33.633
HD Request # 2 | Downloading Intraday chart data for MNQU21-CME to the file MNQU21-CME.scid. Service: cme | 2021-08-17 13:05:33.633
HD Request # 2 | Header check failed: Unknown Intraday file type. Header error. Failed to open the Intraday data file for download. | 2021-08-17 13:05:33.633
HD Request # 2 | Error downloading historical Intraday data for MNQU21-CME. Not downloading any Intraday data for symbol MNQU21-CME. | 2021-08-17 13:05:33.633
Historical data download thread signaled to stop. | 2021-08-17 13:05:33.633
HD Request # 2 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for MNQU21-CME | 2021-08-17 13:05:33.633
HD Request # 2 | Error opening Intraday data files to add Time and Sales records. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for adding records. Error: Unknown Intraday file type. Header error. | 2021-08-17 13:05:33.633
HD Request # 2 | Completion time: 0s | 2021-08-17 13:05:33.633
HD Request # 2 | Intraday data download complete for MNQU21-CME. Unique request ID: 2 | 2021-08-17 13:05:33.633
Removing historical data download ID 2. | 2021-08-17 13:05:33.633
Real-time Intraday chart data file updates started for MNQU21-CME | 2021-08-17 13:05:33.633
Intraday chart data file opened for MNQU21-CME | 2021-08-17 13:05:33.633
HD Request # 2 | Enabling Intraday chart updating for symbol. | 2021-08-17 13:05:33.633
Triggering next historical data download in queue. | 2021-08-17 13:05:33.633
Mapping MNQM21-CME to MNQM21. Service code: cme | 2021-08-17 13:05:33.655
HD Request # 3 | Downloading Intraday chart data for MNQM21-CME to the file MNQM21-CME.scid. Service: cme | 2021-08-17 13:05:33.655
HD Request # 3 | Header check failed: Unknown Intraday file type. Header error. Failed to open the Intraday data file for download. | 2021-08-17 13:05:33.655
HD Request # 3 | Error downloading historical Intraday data for MNQM21-CME. Not downloading any Intraday data for symbol MNQM21-CME. | 2021-08-17 13:05:33.655
Historical data download thread signaled to stop. | 2021-08-17 13:05:33.655
HD Request # 3 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for MNQM21-CME | 2021-08-17 13:05:33.655
HD Request # 3 | Error opening Intraday data files to add Time and Sales records. Header check failed when opening the file C:\SierraChart\Data\MNQM21-CME.scid for adding records. Error: Unknown Intraday file type. Header error. | 2021-08-17 13:05:33.655
HD Request # 3 | Completion time: 0s | 2021-08-17 13:05:33.655
HD Request # 3 | Intraday data download complete for MNQM21-CME. Unique request ID: 4 | 2021-08-17 13:05:33.655
Removing historical data download ID 4. | 2021-08-17 13:05:33.655
Real-time Intraday chart data file updates started for MNQM21-CME | 2021-08-17 13:05:33.655
Intraday chart data file opened for MNQM21-CME | 2021-08-17 13:05:33.655
HD Request # 3 | Enabling Intraday chart updating for symbol. | 2021-08-17 13:05:33.655
Triggering next historical data download in queue. | 2021-08-17 13:05:33.655
Mapping NQU21-CME to NQU21. Service code: cme | 2021-08-17 13:05:33.655
HD Request # 4 | Downloading Intraday chart data for NQU21-CME to the file NQU21-CME.scid. Service: cme | 2021-08-17 13:05:33.655
HD Request # 4 | Header check failed: Unknown Intraday file type. Header error. Failed to open the Intraday data file for download. | 2021-08-17 13:05:33.655
HD Request # 4 | Error downloading historical Intraday data for NQU21-CME. Not downloading any Intraday data for symbol NQU21-CME. | 2021-08-17 13:05:33.655
Historical data download thread signaled to stop. | 2021-08-17 13:05:33.656
HD Request # 4 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for NQU21-CME | 2021-08-17 13:05:33.656
HD Request # 4 | Error opening Intraday data files to add Time and Sales records. Header check failed when opening the file C:\SierraChart\Data\NQU21-CME.scid for adding records. Error: Unknown Intraday file type. Header error. | 2021-08-17 13:05:33.656
HD Request # 4 | Completion time: 0s | 2021-08-17 13:05:33.656
HD Request # 4 | Intraday data download complete for NQU21-CME. Unique request ID: 5 | 2021-08-17 13:05:33.656
Removing historical data download ID 5. | 2021-08-17 13:05:33.656
Real-time Intraday chart data file updates started for NQU21-CME | 2021-08-17 13:05:33.656
Intraday chart data file opened for NQU21-CME | 2021-08-17 13:05:33.656
HD Request # 4 | Enabling Intraday chart updating for symbol. | 2021-08-17 13:05:33.656
Triggering next historical data download in queue. | 2021-08-17 13:05:33.656
No download requests in the queue to start downloads for. | 2021-08-17 13:05:33.656
SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 5 Service code: bitmex | 2021-08-17 13:05:33.861
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2021-08-17 13:05:33.862
SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 5 | 2021-08-17 13:05:33.862
Added historical Intraday data request for XBTUSD-BMEX to the queue. | 2021-08-17 13:05:33.862
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2021-08-17 13:05:33.862
Triggering next historical data download in queue. | 2021-08-17 13:05:33.862
DTC Client socket (2) | Creating socket. | 2021-08-17 13:05:33.862
DTC Client socket (2) | New receive buffer size: 5242880 | 2021-08-17 13:05:33.862
DTC Client socket (2) | Connecting to IP: 204.15.197.14. | 2021-08-17 13:05:33.862
Delaying start of download for XBTUSD-BMEX | 2021-08-17 13:05:33.863
Added historical Daily data request for FDAXM21-EUREX to the queue. | 2021-08-17 13:05:33.868
Triggering next historical data download in queue. | 2021-08-17 13:05:33.868
Mapping FDAXM21-EUREX to FDAX202106_FUT_EUREX. Service code: eurex | 2021-08-17 13:05:33.868
SC DTC Delayed Exchange Data | Starting real-time market data updates for: FDAXM21-EUREX (FDAX202106_FUT_EUREX). ID: 6 Service code: eurex | 2021-08-17 13:05:33.868
SC DTC Delayed Exchange Data | Connecting to the server ds14.sierracharts.com. Port 10043 | 2021-08-17 13:05:33.868
SC DTC Delayed Exchange Data | Requesting security definition data for: FDAXM21-EUREX (FDAX202106_FUT_EUREX). ID: 6 | 2021-08-17 13:05:33.868
DTC Client socket (3) | Creating socket. | 2021-08-17 13:05:33.868
DTC Client socket (3) | New receive buffer size: 5242880 | 2021-08-17 13:05:33.868
DTC Client socket (3) | Connecting to IP: 157.90.1.40. | 2021-08-17 13:05:33.868
SC DTC Data with Market Depth | Starting real-time market data updates for: ADAUSDT-BMEX. ID: 7 Service code: bitmex | 2021-08-17 13:05:33.874
SC DTC Data with Market Depth | Requesting security definition data for: ADAUSDT-BMEX. ID: 7 | 2021-08-17 13:05:33.874
Using Bid/Ask average for last trade price for AUDJPY | 2021-08-17 13:05:33.874
SC DTC Data with Market Depth | Starting real-time market data updates for: AUDJPY. ID: 8 Service code: fxcm | 2021-08-17 13:05:33.874
SC DTC Data with Market Depth | Requesting security definition data for: AUDJPY. ID: 8 | 2021-08-17 13:05:33.874
Using Bid/Ask average for last trade price for AUDNZD | 2021-08-17 13:05:33.874
SC DTC Data with Market Depth | Starting real-time market data updates for: AUDNZD. ID: 9 Service code: fxcm | 2021-08-17 13:05:33.874
SC DTC Data with Market Depth | Requesting security definition data for: AUDNZD. ID: 9 | 2021-08-17 13:05:33.874
Using Bid/Ask average for last trade price for AUDUSD | 2021-08-17 13:05:33.874
SC DTC Data with Market Depth | Starting real-time market data updates for: AUDUSD. ID: 10 Service code: fxcm | 2021-08-17 13:05:33.875
SC DTC Data with Market Depth | Requesting security definition data for: AUDUSD. ID: 10 | 2021-08-17 13:05:33.875
SC DTC Data with Market Depth | Starting real-time market data updates for: BCHUSD-BMEX. ID: 11 Service code: bitmex | 2021-08-17 13:05:33.875
SC DTC Data with Market Depth | Requesting security definition data for: BCHUSD-BMEX. ID: 11 | 2021-08-17 13:05:33.875
SC DTC Data with Market Depth | Starting real-time market data updates for: BNBUSDT-BMEX. ID: 12 Service code: bitmex | 2021-08-17 13:05:33.875
SC DTC Data with Market Depth | Requesting security definition data for: BNBUSDT-BMEX. ID: 12 | 2021-08-17 13:05:33.875
Using Bid/Ask average for last trade price for Bund | 2021-08-17 13:05:33.875
SC DTC Data with Market Depth | Starting real-time market data updates for: Bund. ID: 13 Service code: fxcm | 2021-08-17 13:05:33.875
SC DTC Data with Market Depth | Requesting security definition data for: Bund. ID: 13 | 2021-08-17 13:05:33.875
Using Bid/Ask average for last trade price for CADJPY | 2021-08-17 13:05:33.875
SC DTC Data with Market Depth | Starting real-time market data updates for: CADJPY. ID: 14 Service code: fxcm | 2021-08-17 13:05:33.875
SC DTC Data with Market Depth | Requesting security definition data for: CADJPY. ID: 14 | 2021-08-17 13:05:33.875
Using Bid/Ask average for last trade price for CHN50 | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Starting real-time market data updates for: CHN50. ID: 15 Service code: fxcm | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Requesting security definition data for: CHN50. ID: 15 | 2021-08-17 13:05:33.876
Using Bid/Ask average for last trade price for Copper | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Starting real-time market data updates for: Copper. ID: 16 Service code: fxcm | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Requesting security definition data for: Copper. ID: 16 | 2021-08-17 13:05:33.876
Using Bid/Ask average for last trade price for CORNF | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Starting real-time market data updates for: CORNF. ID: 17 Service code: fxcm | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Requesting security definition data for: CORNF. ID: 17 | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Starting real-time market data updates for: DOGEUSDT-BMEX. ID: 18 Service code: bitmex | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Requesting security definition data for: DOGEUSDT-BMEX. ID: 18 | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Starting real-time market data updates for: DOTUSDT-BMEX. ID: 19 Service code: bitmex | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Requesting security definition data for: DOTUSDT-BMEX. ID: 19 | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Starting real-time market data updates for: EOSUSDT-BMEX. ID: 20 Service code: bitmex | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Requesting security definition data for: EOSUSDT-BMEX. ID: 20 | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BMEX. ID: 21 Service code: bitmex | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BMEX. ID: 21 | 2021-08-17 13:05:33.876
Using Bid/Ask average for last trade price for EURAUD | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Starting real-time market data updates for: EURAUD. ID: 22 Service code: fxcm | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Requesting security definition data for: EURAUD. ID: 22 | 2021-08-17 13:05:33.876
Using Bid/Ask average for last trade price for EURCAD | 2021-08-17 13:05:33.876
SC DTC Data with Market Depth | Starting real-time market data updates for: EURCAD. ID: 23 Service code: fxcm | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Requesting security definition data for: EURCAD. ID: 23 | 2021-08-17 13:05:33.877
Using Bid/Ask average for last trade price for EURCHF | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Starting real-time market data updates for: EURCHF. ID: 24 Service code: fxcm | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Requesting security definition data for: EURCHF. ID: 24 | 2021-08-17 13:05:33.877
Using Bid/Ask average for last trade price for EURGBP | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Starting real-time market data updates for: EURGBP. ID: 25 Service code: fxcm | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Requesting security definition data for: EURGBP. ID: 25 | 2021-08-17 13:05:33.877
Using Bid/Ask average for last trade price for EURJPY | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Starting real-time market data updates for: EURJPY. ID: 26 Service code: fxcm | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Requesting security definition data for: EURJPY. ID: 26 | 2021-08-17 13:05:33.877
Using Bid/Ask average for last trade price for EURNZD | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Starting real-time market data updates for: EURNZD. ID: 27 Service code: fxcm | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Requesting security definition data for: EURNZD. ID: 27 | 2021-08-17 13:05:33.877
Using Bid/Ask average for last trade price for EURTRY | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Starting real-time market data updates for: EURTRY. ID: 28 Service code: fxcm | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Requesting security definition data for: EURTRY. ID: 28 | 2021-08-17 13:05:33.877
Using Bid/Ask average for last trade price for EURUSD | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 29 Service code: fxcm | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 29 | 2021-08-17 13:05:33.877
Using Bid/Ask average for last trade price for GBPAUD | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPAUD. ID: 30 Service code: fxcm | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Requesting security definition data for: GBPAUD. ID: 30 | 2021-08-17 13:05:33.877
Using Bid/Ask average for last trade price for GBPCAD | 2021-08-17 13:05:33.877
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPCAD. ID: 31 Service code: fxcm | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Requesting security definition data for: GBPCAD. ID: 31 | 2021-08-17 13:05:33.878
Using Bid/Ask average for last trade price for GBPCHF | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPCHF. ID: 32 Service code: fxcm | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Requesting security definition data for: GBPCHF. ID: 32 | 2021-08-17 13:05:33.878
Using Bid/Ask average for last trade price for GBPJPY | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPJPY. ID: 33 Service code: fxcm | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Requesting security definition data for: GBPJPY. ID: 33 | 2021-08-17 13:05:33.878
Using Bid/Ask average for last trade price for GBPNZD | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPNZD. ID: 34 Service code: fxcm | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Requesting security definition data for: GBPNZD. ID: 34 | 2021-08-17 13:05:33.878
Using Bid/Ask average for last trade price for GBPUSD | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPUSD. ID: 35 Service code: fxcm | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Requesting security definition data for: GBPUSD. ID: 35 | 2021-08-17 13:05:33.878
Using Bid/Ask average for last trade price for GER30 | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Starting real-time market data updates for: GER30. ID: 36 Service code: fxcm | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Requesting security definition data for: GER30. ID: 36 | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Starting real-time market data updates for: LINKUSDT-BMEX. ID: 37 Service code: bitmex | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Requesting security definition data for: LINKUSDT-BMEX. ID: 37 | 2021-08-17 13:05:33.878
SC DTC Data with Market Depth | Starting real-time market data updates for: LTCUSD-BMEX. ID: 38 Service code: bitmex | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Requesting security definition data for: LTCUSD-BMEX. ID: 38 | 2021-08-17 13:05:33.879
Using Bid/Ask average for last trade price for NAS100 | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Starting real-time market data updates for: NAS100. ID: 39 Service code: fxcm | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Requesting security definition data for: NAS100. ID: 39 | 2021-08-17 13:05:33.879
Using Bid/Ask average for last trade price for NGAS | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Starting real-time market data updates for: NGAS. ID: 40 Service code: fxcm | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Requesting security definition data for: NGAS. ID: 40 | 2021-08-17 13:05:33.879
Using Bid/Ask average for last trade price for NZDUSD | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Starting real-time market data updates for: NZDUSD. ID: 41 Service code: fxcm | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Requesting security definition data for: NZDUSD. ID: 41 | 2021-08-17 13:05:33.879
Using Bid/Ask average for last trade price for SOYF | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Starting real-time market data updates for: SOYF. ID: 42 Service code: fxcm | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Requesting security definition data for: SOYF. ID: 42 | 2021-08-17 13:05:33.879
Using Bid/Ask average for last trade price for SPX500 | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Starting real-time market data updates for: SPX500. ID: 43 Service code: fxcm | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Requesting security definition data for: SPX500. ID: 43 | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Starting real-time market data updates for: TRXUSDT-BMEX. ID: 44 Service code: bitmex | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Requesting security definition data for: TRXUSDT-BMEX. ID: 44 | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Starting real-time market data updates for: UNIUSDT-BMEX. ID: 45 Service code: bitmex | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Requesting security definition data for: UNIUSDT-BMEX. ID: 45 | 2021-08-17 13:05:33.879
Using Bid/Ask average for last trade price for US30 | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Starting real-time market data updates for: US30. ID: 46 Service code: fxcm | 2021-08-17 13:05:33.879
SC DTC Data with Market Depth | Requesting security definition data for: US30. ID: 46 | 2021-08-17 13:05:33.879
Using Bid/Ask average for last trade price for USDCHF | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Starting real-time market data updates for: USDCHF. ID: 47 Service code: fxcm | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Requesting security definition data for: USDCHF. ID: 47 | 2021-08-17 13:05:33.880
Using Bid/Ask average for last trade price for USDJPY | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Starting real-time market data updates for: USDJPY. ID: 48 Service code: fxcm | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Requesting security definition data for: USDJPY. ID: 48 | 2021-08-17 13:05:33.880
Using Bid/Ask average for last trade price for USOil | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Starting real-time market data updates for: USOil. ID: 49 Service code: fxcm | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Requesting security definition data for: USOil. ID: 49 | 2021-08-17 13:05:33.880
Using Bid/Ask average for last trade price for WHEATF | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Starting real-time market data updates for: WHEATF. ID: 50 Service code: fxcm | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Requesting security definition data for: WHEATF. ID: 50 | 2021-08-17 13:05:33.880
Using Bid/Ask average for last trade price for XAGUSD | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Starting real-time market data updates for: XAGUSD. ID: 51 Service code: fxcm | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Requesting security definition data for: XAGUSD. ID: 51 | 2021-08-17 13:05:33.880
Using Bid/Ask average for last trade price for XAUUSD | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Starting real-time market data updates for: XAUUSD. ID: 52 Service code: fxcm | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Requesting security definition data for: XAUUSD. ID: 52 | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Starting real-time market data updates for: XLMUSDT-BMEX. ID: 53 Service code: bitmex | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Requesting security definition data for: XLMUSDT-BMEX. ID: 53 | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Starting real-time market data updates for: XRPUSD-BMEX. ID: 54 Service code: bitmex | 2021-08-17 13:05:33.880
SC DTC Data with Market Depth | Requesting security definition data for: XRPUSD-BMEX. ID: 54 | 2021-08-17 13:05:33.880
SC DTC Delayed Exchange Data | Network connection to server complete. | 2021-08-17 13:05:33.903
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2021-08-17 13:05:33.903
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2021-08-17 13:05:33.903
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2021-08-17 13:05:33.949
SC DTC Delayed Exchange Data | Sending logon request message. | 2021-08-17 13:05:33.949
HD Request # 1 | Requesting historical Daily data for DYU21 starting at 2021-08-11. SC External HD service. | 2021-08-17 13:05:33.983
SC DTC Data with Market Depth | Network connection to server complete. | 2021-08-17 13:05:34.003
SC DTC Data with Market Depth | Starting socket receive thread. | 2021-08-17 13:05:34.003
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2021-08-17 13:05:34.003
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-08-17 13:05:34.168
SC DTC Data with Market Depth | Sending logon request message. | 2021-08-17 13:05:34.168
SC DTC Delayed Exchange Data | Received logon response. | 2021-08-17 13:05:34.193
SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2021-08-17 13:05:34.193
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2021-08-17 13:05:34.193
SC DTC Delayed Exchange Data | Successfully connected. | 2021-08-17 13:05:34.193
SC DTC Delayed Exchange Data | Trading is not supported. | 2021-08-17 13:05:34.193
SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: FDAXM21-EUREX -> FDAX202106_FUT_EUREX | 2021-08-17 13:05:34.193
SC DTC Delayed Exchange Data | Real-time data for symbol FDAXM21-EUREX is currently unavailable. | 2021-08-17 13:05:34.318
SC DTC Delayed Exchange Data | Received security definition for symbol FDAXM21-EUREX | 2021-08-17 13:05:34.318
SC DTC Data with Market Depth | Received logon response. | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Successfully connected. | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Trading is not supported. | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADAUSDT-BMEX | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDJPY | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDNZD | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDUSD | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BCHUSD-BMEX | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BNBUSDT-BMEX | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: Bund | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CADJPY | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CHN50 | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: Copper | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CORNF | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DOGEUSDT-BMEX | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DOTUSDT-BMEX | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EOSUSDT-BMEX | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BMEX | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURAUD | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURCAD | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURCHF | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURGBP | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURJPY | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURNZD | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURTRY | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPAUD | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPCAD | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPCHF | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPJPY | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPNZD | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPUSD | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GER30 | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: LINKUSDT-BMEX | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: LTCUSD-BMEX | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NAS100 | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NGAS | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDUSD | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SOYF | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRXUSDT-BMEX | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: UNIUSDT-BMEX | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCHF | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDJPY | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: WHEATF | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAGUSD | 2021-08-17 13:05:34.919
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2021-08-17 13:05:34.920
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2021-08-17 13:05:34.920
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XLMUSDT-BMEX | 2021-08-17 13:05:34.920
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XRPUSD-BMEX | 2021-08-17 13:05:34.920
HD Request # 1 | Receiving historical Daily data for FDAXU21-EUREX starting at 2021-08-12 | 2021-08-17 13:05:34.920
HD Request # 1 | Writing historical Daily data to the file FDAXU21-EUREX.dly | 2021-08-17 13:05:34.920
HD Request # 1 | Bytes received: 216 | 2021-08-17 13:05:34.923
HD Request # 1 | Received 4 Daily data records from 2021-08-12 00:00:00 to 2021-08-16 00:00:00 (5.0 days) and wrote 3 records for FDAXU21-EUREX | 2021-08-17 13:05:34.923
HD Request # 1 | Completion time: 1s | 2021-08-17 13:05:34.924
HD Request # 1 | Daily data download complete for FDAXU21-EUREX. Unique request ID: 1 | 2021-08-17 13:05:34.924
Removing historical data download ID 1. | 2021-08-17 13:05:34.924
Triggering next historical data download in queue. | 2021-08-17 13:05:34.924
HD Request # 5 | Downloading Historical Daily chart data for MNQU21-CME. Starting date: 2021-08-13. Service: scdataallservices | 2021-08-17 13:05:34.925
HD Request # 5 | Requesting historical Daily data for NMU21 starting at 2021-08-12. SC External HD service. | 2021-08-17 13:05:35.240
SC DTC Data with Market Depth | Received security definition for symbol ADAUSDT-BMEX | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol AUDJPY | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol AUDNZD | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol AUDUSD | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol BCHUSD-BMEX | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol BNBUSDT-BMEX | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol Bund | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol CADJPY | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol CHN50 | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol Copper | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol CORNF | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol DOGEUSDT-BMEX | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol DOTUSDT-BMEX | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol EOSUSDT-BMEX | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol EURAUD | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol EURCAD | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol EURCHF | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol EURGBP | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol EURJPY | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol EURNZD | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol EURTRY | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol GBPAUD | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol GBPCAD | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol GBPCHF | 2021-08-17 13:05:35.267
SC DTC Data with Market Depth | Received security definition for symbol GBPJPY | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol GBPNZD | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol GBPUSD | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol GER30 | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol LINKUSDT-BMEX | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol LTCUSD-BMEX | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol NAS100 | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol NGAS | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol NZDUSD | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol SOYF | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol TRXUSDT-BMEX | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol UNIUSDT-BMEX | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol US30 | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol USDCHF | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol USDJPY | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol USOil | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol WHEATF | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol XAGUSD | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol XLMUSDT-BMEX | 2021-08-17 13:05:35.268
SC DTC Data with Market Depth | Received security definition for symbol XRPUSD-BMEX | 2021-08-17 13:05:35.268
FDAXU21-EUREX/FDXMU21-EUREX [CBV] 1000 Trades #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-08-17 13:05:35.313
FDAXU21-EUREX/FDXMU21-EUREX [CBV] 1000 Trades #1 | Reloading chart. | 2021-08-17 13:05:35.314
FDAXU21-EUREX/FDXMU21-EUREX [CBV] 1000 Trades #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-08-17 13:05:35.540
HD Request # 5 | Receiving historical Daily data for MNQU21-CME starting at 2021-08-13 | 2021-08-17 13:05:35.805
HD Request # 5 | Writing historical Daily data to the file MNQU21-CME.dly | 2021-08-17 13:05:35.805
HD Request # 5 | Bytes received: 242 | 2021-08-17 13:05:35.811
HD Request # 5 | Received 4 Daily data records from 2021-08-13 00:00:00 to 2021-08-17 00:00:00 (5.0 days) and wrote 3 records for MNQU21-CME | 2021-08-17 13:05:35.811
HD Request # 5 | Completion time: 1s | 2021-08-17 13:05:35.811
HD Request # 5 | Daily data download complete for MNQU21-CME. Unique request ID: 3 | 2021-08-17 13:05:35.811
Removing historical data download ID 3. | 2021-08-17 13:05:35.811
Triggering next historical data download in queue. | 2021-08-17 13:05:35.811
HD Request # 6 | Downloading Historical Daily chart data for NQU21-CME. Starting date: 2021-08-13. Service: scdataallservices | 2021-08-17 13:05:35.814
FDAXU21-EUREX/FDXMU21-EUREX [CBV] 1000 Trades #1 | Reloading chart. | 2021-08-17 13:05:35.817
MNQU21-CME [CBV] 1500 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-08-17 13:05:35.882
MNQU21-CME [CBV] 1500 Trades #4 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:35.882
MNQU21-CME [CBV] 1500 Trades #4 | Reloading chart. | 2021-08-17 13:05:35.882
MNQU21-CME [CBV] 1500 Trades #4 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:35.887
Unknown Intraday file type. Header error. C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:35.888
MNQU21-CME [CBV] 1500 Trades #4 | Error opening or reading chart data file. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:35.894
FDAXU21-EUREX/FDXMU21-EUREX [CBV] 1000 Trades #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-08-17 13:05:36.029
MNQU21-CME [CBV] 500 Trades #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-08-17 13:05:36.055
MNQU21-CME [CBV] 500 Trades #8 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.055
MNQU21-CME [CBV] 500 Trades #8 | Reloading chart. | 2021-08-17 13:05:36.055
MNQU21-CME [CBV] 500 Trades #8 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.060
Unknown Intraday file type. Header error. C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.061
MNQU21-CME [CBV] 500 Trades #8 | Error opening or reading chart data file. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.063
MNQU21-CME/FDXMU21-EUREX [CBV] 500 Volume #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-08-17 13:05:36.090
MNQU21-CME/FDXMU21-EUREX [CBV] 500 Volume #3 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.091
MNQU21-CME/FDXMU21-EUREX [CBV] 500 Volume #3 | Reloading chart. | 2021-08-17 13:05:36.091
MNQU21-CME/FDXMU21-EUREX [CBV] 500 Volume #3 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.095
Unknown Intraday file type. Header error. C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.096
MNQU21-CME/FDXMU21-EUREX [CBV] 500 Volume #3 | Error opening or reading chart data file. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.097
MNQU21-CME [CBV] 5000 Trades #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-08-17 13:05:36.134
MNQU21-CME [CBV] 5000 Trades #5 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.134
MNQU21-CME [CBV] 5000 Trades #5 | Reloading chart. | 2021-08-17 13:05:36.134
MNQU21-CME [CBV] 5000 Trades #5 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.158
HD Request # 6 | Requesting historical Daily data for NQU21 starting at 2021-08-12. SC External HD service. | 2021-08-17 13:05:36.158
Unknown Intraday file type. Header error. C:\SierraChart\Data\MNQM21-CME.scid | 2021-08-17 13:05:36.160
Unknown Intraday file type. Header error. C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.160
MNQU21-CME [CBV] 5000 Trades #5 | Error opening or reading chart data file. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.163
Mapping FDXMU21-EUREX to FDXM202109_FUT_EUREX. Service code: eurex | 2021-08-17 13:05:36.322
SC DTC Delayed Exchange Data | Starting real-time market data updates for: FDXMU21-EUREX (FDXM202109_FUT_EUREX). ID: 55 Service code: eurex | 2021-08-17 13:05:36.322
SC DTC Delayed Exchange Data | Requesting security definition data for: FDXMU21-EUREX (FDXM202109_FUT_EUREX). ID: 55 | 2021-08-17 13:05:36.322
SC DTC Delayed Exchange Data | Starting real-time market data updates for: FDAXU21-EUREX (FDAX202109_FUT_EUREX). ID: 1 Service code: eurex | 2021-08-17 13:05:36.322
SC DTC Delayed Exchange Data | Requesting security definition data for: FDAXU21-EUREX (FDAX202109_FUT_EUREX). ID: 1 | 2021-08-17 13:05:36.322
Added historical Intraday data request for FDAXU21-EUREX to the queue. | 2021-08-17 13:05:36.322
Intraday data recording state for symbol FDAXU21-EUREX is set to download 'Pending'. | 2021-08-17 13:05:36.322
Triggering next historical data download in queue. | 2021-08-17 13:05:36.323
MNQU21-CME [CBV] 1500 Trades #4 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.385
MNQU21-CME [CBV] 1500 Trades #4 | Reloading chart. | 2021-08-17 13:05:36.385
MNQU21-CME [CBV] 1500 Trades #4 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.408
Unknown Intraday file type. Header error. C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.409
MNQU21-CME [CBV] 1500 Trades #4 | Error opening or reading chart data file. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.416
SC DTC Delayed Exchange Data | Received security definition for symbol FDXMU21-EUREX | 2021-08-17 13:05:36.481
SC DTC Delayed Exchange Data | Received security definition for symbol FDAXU21-EUREX | 2021-08-17 13:05:36.481
MNQU21-CME [CBV] 500 Trades #8 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.558
MNQU21-CME [CBV] 500 Trades #8 | Reloading chart. | 2021-08-17 13:05:36.558
MNQU21-CME [CBV] 500 Trades #8 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.576
Unknown Intraday file type. Header error. C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.577
MNQU21-CME [CBV] 500 Trades #8 | Error opening or reading chart data file. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.579
MNQU21-CME/FDXMU21-EUREX [CBV] 500 Volume #3 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.588
MNQU21-CME/FDXMU21-EUREX [CBV] 500 Volume #3 | Reloading chart. | 2021-08-17 13:05:36.589
MNQU21-CME/FDXMU21-EUREX [CBV] 500 Volume #3 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.608
Unknown Intraday file type. Header error. C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.608
MNQU21-CME/FDXMU21-EUREX [CBV] 500 Volume #3 | Error opening or reading chart data file. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.609
MNQU21-CME [CBV] 5000 Trades #5 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.636
MNQU21-CME [CBV] 5000 Trades #5 | Reloading chart. | 2021-08-17 13:05:36.636
MNQU21-CME [CBV] 5000 Trades #5 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.683
Unknown Intraday file type. Header error. C:\SierraChart\Data\MNQM21-CME.scid | 2021-08-17 13:05:36.683
Unknown Intraday file type. Header error. C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.683
MNQU21-CME [CBV] 5000 Trades #5 | Error opening or reading chart data file. File: C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:36.685
HD Request # 6 | Receiving historical Daily data for NQU21-CME starting at 2021-08-13 | 2021-08-17 13:05:36.719
HD Request # 6 | Writing historical Daily data to the file NQU21-CME.dly | 2021-08-17 13:05:36.719
HD Request # 6 | Bytes received: 253 | 2021-08-17 13:05:36.721
HD Request # 6 | Received 4 Daily data records from 2021-08-13 00:00:00 to 2021-08-17 00:00:00 (5.0 days) and wrote 3 records for NQU21-CME | 2021-08-17 13:05:36.721
HD Request # 6 | Completion time: 1s | 2021-08-17 13:05:36.721
HD Request # 6 | Daily data download complete for NQU21-CME. Unique request ID: 6 | 2021-08-17 13:05:36.721
Removing historical data download ID 6. | 2021-08-17 13:05:36.722
Triggering next historical data download in queue. | 2021-08-17 13:05:36.722
HD Request # 7 | Downloading Historical Daily chart data for FDAXM21-EUREX. Starting date: 2021-06-16. Service: eurex | 2021-08-17 13:05:36.723
NQU21-CME [CBV] 500 Trades #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-08-17 13:05:36.858
NQU21-CME [CBV] 500 Trades #6 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\NQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\NQU21-CME.scid | 2021-08-17 13:05:36.859
NQU21-CME [CBV] 500 Trades #6 | Reloading chart. | 2021-08-17 13:05:36.859
NQU21-CME [CBV] 500 Trades #6 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\NQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\NQU21-CME.scid | 2021-08-17 13:05:36.863
Unknown Intraday file type. Header error. C:\SierraChart\Data\NQU21-CME.scid | 2021-08-17 13:05:36.865
NQU21-CME [CBV] 500 Trades #6 | Error opening or reading chart data file. File: C:\SierraChart\Data\NQU21-CME.scid | 2021-08-17 13:05:36.866
SC Data - All Services | Starting real-time market data updates for: MNQU21-CME (MNQU21). ID: 2 Service code: cme | 2021-08-17 13:05:36.889
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2021-08-17 13:05:36.889
SC Data - All Services | Requesting security definition data for: MNQU21-CME (MNQU21). ID: 2 | 2021-08-17 13:05:36.889
DTC Client socket (5) | Creating socket. | 2021-08-17 13:05:36.955
DTC Client socket (5) | New receive buffer size: 5242880 | 2021-08-17 13:05:36.956
DTC Client socket (5) | Connecting to IP: 208.185.224.129. | 2021-08-17 13:05:36.956
HD Request # 7 | Requesting historical Daily data for DYM21 starting at 2021-06-15. SC External HD service. | 2021-08-17 13:05:37.037
SC Data - All Services | Network connection to server complete. | 2021-08-17 13:05:37.074
SC Data - All Services | Starting socket receive thread. | 2021-08-17 13:05:37.074
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-08-17 13:05:37.074
SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-08-17 13:05:37.216
SC Data - All Services | Sending logon request message. | 2021-08-17 13:05:37.216
NQU21-CME [CBV] 500 Trades #6 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\NQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\NQU21-CME.scid | 2021-08-17 13:05:37.344
NQU21-CME [CBV] 500 Trades #6 | Reloading chart. | 2021-08-17 13:05:37.345
NQU21-CME [CBV] 500 Trades #6 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\Data\NQU21-CME.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart\Data\NQU21-CME.scid | 2021-08-17 13:05:37.362
Unknown Intraday file type. Header error. C:\SierraChart\Data\NQU21-CME.scid | 2021-08-17 13:05:37.363
NQU21-CME [CBV] 500 Trades #6 | Error opening or reading chart data file. File: C:\SierraChart\Data\NQU21-CME.scid | 2021-08-17 13:05:37.364
HD Request # 7 | Receiving historical Daily data for FDAXM21-EUREX starting at 2021-06-16 | 2021-08-17 13:05:37.584
HD Request # 7 | Writing historical Daily data to the file FDAXM21-EUREX.dly | 2021-08-17 13:05:37.584
HD Request # 7 | Bytes received: 213 | 2021-08-17 13:05:37.588
HD Request # 7 | Received 4 Daily data records from 2021-06-16 00:00:00 to 2021-06-18 00:00:00 (3.0 days) and wrote 3 records for FDAXM21-EUREX | 2021-08-17 13:05:37.588
HD Request # 7 | Completion time: 1s | 2021-08-17 13:05:37.588
HD Request # 7 | Daily data download complete for FDAXM21-EUREX. Unique request ID: 8 | 2021-08-17 13:05:37.588
Removing historical data download ID 8. | 2021-08-17 13:05:37.588
Triggering next historical data download in queue. | 2021-08-17 13:05:37.588
No download requests in the queue to start downloads for. | 2021-08-17 13:05:37.588
SC Data - All Services | Starting real-time market data updates for: NQU21-CME (NQU21). ID: 4 Service code: cme | 2021-08-17 13:05:37.850
SC Data - All Services | Requesting security definition data for: NQU21-CME (NQU21). ID: 4 | 2021-08-17 13:05:37.850
FDAXM21-EUREX[M] Daily #2 | Reloading chart. | 2021-08-17 13:05:37.852
SC Data - All Services | Received logon response. | 2021-08-17 13:05:38.086
SC Data - All Services | Server Name: SC Realtime Server. | 2021-08-17 13:05:38.086
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-08-17 13:05:38.086
SC Data - All Services | Successfully connected. | 2021-08-17 13:05:38.086
SC Data - All Services | Trading is not supported. | 2021-08-17 13:05:38.086
Added historical Intraday data request for MNQU21-CME to the queue. | 2021-08-17 13:05:38.086
Intraday data recording state for symbol MNQU21-CME is set to download 'Pending'. | 2021-08-17 13:05:38.086
Triggering next historical data download in queue. | 2021-08-17 13:05:38.086
SC Data - All Services | Restarting real-time data updates for symbol: MNQU21-CME -> MNQU21 | 2021-08-17 13:05:38.086
Added historical Intraday data request for NQU21-CME to the queue. | 2021-08-17 13:05:38.086
Intraday data recording state for symbol NQU21-CME is set to download 'Pending'. | 2021-08-17 13:05:38.086
SC Data - All Services | Restarting real-time data updates for symbol: NQU21-CME -> NQU21 | 2021-08-17 13:05:38.086
SC Data - All Services | Received security definition for symbol MNQU21-CME | 2021-08-17 13:05:38.305
SC Data - All Services | Received security definition for symbol NQU21-CME | 2021-08-17 13:05:38.305
HD Request # 8 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2021-08-17 13:05:40.619
HD Request # 8 | Header check failed: Unknown Intraday file type. Header error. Failed to open the Intraday data file for download. | 2021-08-17 13:05:40.619
HD Request # 8 | Error downloading historical Intraday data for XBTUSD-BMEX. Not downloading any Intraday data for symbol XBTUSD-BMEX. | 2021-08-17 13:05:40.619
Historical data download thread signaled to stop. | 2021-08-17 13:05:40.619
HD Request # 8 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for XBTUSD-BMEX | 2021-08-17 13:05:40.619
HD Request # 8 | Error opening Intraday data files to add Time and Sales records. Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for adding records. Error: Unknown Intraday file type. Header error. | 2021-08-17 13:05:40.620
HD Request # 8 | Completion time: 0s | 2021-08-17 13:05:40.620
HD Request # 8 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 7 | 2021-08-17 13:05:40.620
Removing historical data download ID 7. | 2021-08-17 13:05:40.620
Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2021-08-17 13:05:40.620
Intraday chart data file opened for XBTUSD-BMEX | 2021-08-17 13:05:40.620
HD Request # 8 | Enabling Intraday chart updating for symbol. | 2021-08-17 13:05:40.620
Triggering next historical data download in queue. | 2021-08-17 13:05:40.620
Delaying start of download for FDAXU21-EUREX | 2021-08-17 13:05:40.620
Error opening Intraday file: Header check failed when opening the file C:\SierraChart\Data\XBTUSD-BMEX.scid for adding records. Error: Unknown Intraday file type. Header error. | 2021-08-17 13:05:41.565
HD Request # 9 | Downloading Intraday chart data for FDAXU21-EUREX to the file FDAXU21-EUREX.scid. Service: eurex | 2021-08-17 13:05:41.613
HD Request # 9 | Download start date-time: 2021-08-17 12:47:34.000000. File last date-time: 2021-08-17 12:47:34.529000 | 2021-08-17 13:05:41.613
HD Request # 9 | Using server: ds24.sierracharts.com port 10149 | 2021-08-17 13:05:41.613
Socket (1) | Creating socket. | 2021-08-17 13:05:41.614
Socket (1) | New receive buffer size: 5242880 | 2021-08-17 13:05:41.614
Socket (1) | Connecting to IP: 80.81.77.132. | 2021-08-17 13:05:41.614
HD Request # 9 | Setting DTC encoding to Binary VLS | 2021-08-17 13:05:41.747
HD Request # 9 | Sending historical data logon request message. | 2021-08-17 13:05:41.748
HD Request # 9 | Requesting Intraday data. Start date-time: 2021-08-17 12:47:34. Record interval: 0. Symbol: FDAX202109_FUT_EUREX | 2021-08-17 13:05:41.918
HD Request # 9 | Decompressing data. | 2021-08-17 13:05:41.987
HD Request # 9 | Receiving Intraday data for FDAXU21-EUREX starting at 2021-08-17 12:47:34.529000 | 2021-08-17 13:05:41.988
Socket (1) | CloseSocket call. | 2021-08-17 13:05:41.989
Socket (1) | Shutdown started. Waiting for graceful close. | 2021-08-17 13:05:41.989
Historical data download thread signaled to stop. | 2021-08-17 13:05:41.989
HD Request # 9 | Timestamp of first Intraday data file record written: 2021-08-17 12:48:13.945000 | 2021-08-17 13:05:41.989
HD Request # 9 | Received 113 Intraday data records from 2021-08-17 12:47:34.529000 to 2021-08-17 12:50:38.830000 (3.1 minutes) and wrote 112 records for FDAXU21-EUREX | 2021-08-17 13:05:41.989
HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2021-08-17 10:50:38.830000 | 2021-08-17 13:05:41.990
HD Request # 9 | Completion time: 0s | 2021-08-17 13:05:41.990
HD Request # 9 | Intraday data download complete for FDAXU21-EUREX. Unique request ID: 9 | 2021-08-17 13:05:41.990
Removing historical data download ID 9. | 2021-08-17 13:05:41.990
Real-time Intraday chart data file updates started for FDAXU21-EUREX | 2021-08-17 13:05:41.990
Intraday chart data file opened for FDAXU21-EUREX | 2021-08-17 13:05:41.990
HD Request # 9 | Enabling Intraday chart updating for symbol. | 2021-08-17 13:05:41.990
Triggering next historical data download in queue. | 2021-08-17 13:05:41.990
Delaying start of download for MNQU21-CME | 2021-08-17 13:05:41.990
Socket (1) | Socket gracefully closed by remote side. | 2021-08-17 13:05:42.054
Socket (1) | Closed. | 2021-08-17 13:05:42.054
HD Request # 10 | Downloading Intraday chart data for MNQU21-CME to the file MNQU21-CME.scid. Service: cme | 2021-08-17 13:05:43.617
HD Request # 10 | Header check failed: Unknown Intraday file type. Header error. Failed to open the Intraday data file for download. | 2021-08-17 13:05:43.617
HD Request # 10 | Error downloading historical Intraday data for MNQU21-CME. Not downloading any Intraday data for symbol MNQU21-CME. | 2021-08-17 13:05:43.617
Historical data download thread signaled to stop. | 2021-08-17 13:05:43.617
HD Request # 10 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for MNQU21-CME | 2021-08-17 13:05:43.617
HD Request # 10 | Error opening Intraday data files to add Time and Sales records. Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for adding records. Error: Unknown Intraday file type. Header error. | 2021-08-17 13:05:43.617
HD Request # 10 | Completion time: 0s | 2021-08-17 13:05:43.617
HD Request # 10 | Intraday data download complete for MNQU21-CME. Unique request ID: 10 | 2021-08-17 13:05:43.617
Removing historical data download ID 10. | 2021-08-17 13:05:43.617
Real-time Intraday chart data file updates started for MNQU21-CME | 2021-08-17 13:05:43.617
Intraday chart data file opened for MNQU21-CME | 2021-08-17 13:05:43.617
HD Request # 10 | Enabling Intraday chart updating for symbol. | 2021-08-17 13:05:43.617
Triggering next historical data download in queue. | 2021-08-17 13:05:43.618
HD Request # 11 | Downloading Intraday chart data for NQU21-CME to the file NQU21-CME.scid. Service: cme | 2021-08-17 13:05:43.618
HD Request # 11 | Header check failed: Unknown Intraday file type. Header error. Failed to open the Intraday data file for download. | 2021-08-17 13:05:43.618
HD Request # 11 | Error downloading historical Intraday data for NQU21-CME. Not downloading any Intraday data for symbol NQU21-CME. | 2021-08-17 13:05:43.618
Historical data download thread signaled to stop. | 2021-08-17 13:05:43.618
HD Request # 11 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for NQU21-CME | 2021-08-17 13:05:43.618
HD Request # 11 | Error opening Intraday data files to add Time and Sales records. Header check failed when opening the file C:\SierraChart\Data\NQU21-CME.scid for adding records. Error: Unknown Intraday file type. Header error. | 2021-08-17 13:05:43.618
HD Request # 11 | Completion time: 0s | 2021-08-17 13:05:43.618
HD Request # 11 | Intraday data download complete for NQU21-CME. Unique request ID: 11 | 2021-08-17 13:05:43.618
Removing historical data download ID 11. | 2021-08-17 13:05:43.618
Real-time Intraday chart data file updates started for NQU21-CME | 2021-08-17 13:05:43.618
Intraday chart data file opened for NQU21-CME | 2021-08-17 13:05:43.618
HD Request # 11 | Enabling Intraday chart updating for symbol. | 2021-08-17 13:05:43.618
No download requests in the queue to start downloads for. | 2021-08-17 13:05:43.618
Opened cached Intraday file: C:\SierraChart\Data\FDAXU21-EUREX.scid. Thread ID: 8384 | 2021-08-17 13:05:44.136
File open error encountered. Not allowing writing. C:\SierraChart\Data\XBTUSD-BMEX.scid | 2021-08-17 13:05:46.282
Error opening Intraday file: Header check failed when opening the file C:\SierraChart\Data\NQU21-CME.scid for adding records. Error: Unknown Intraday file type. Header error. | 2021-08-17 13:05:46.604
File open error encountered. Not allowing writing. C:\SierraChart\Data\NQU21-CME.scid | 2021-08-17 13:05:49.002
Error opening Intraday file: Header check failed when opening the file C:\SierraChart\Data\MNQU21-CME.scid for adding records. Error: Unknown Intraday file type. Header error. | 2021-08-17 13:05:51.618
File open error encountered. Not allowing writing. C:\SierraChart\Data\MNQU21-CME.scid | 2021-08-17 13:05:52.495
imagesce.PNG / V - Attached On 2021-08-17 11:15:50 UTC - Size: 7.24 KB - 160 views
[2021-08-17 11:57:01]
This is the problem:
For every symbol, where you are getting a header error , delete the chart data file following these instructions:
Chart Data and Chart Data Files: Deleting a Chart Data File
[2021-08-17 12:12:38]
artmaan - Posts: 26
great, thank you, it worked.
