Date/Time: Fri, 28 Feb 2025 09:20:52 +0000
Charting Stocks Real Time
View Count: 559
[2021-08-17 03:29:58]
george3232 - Posts: 2
Can Sierra be used to chart stocks in real time? Large and small cap stocks low float stocks? I see some things online, but I wanted to be sure I'm accessing the correct thing. It says to activate the real time connection "25.00 USD [Prorated to 13.00 USD for current month (15 days)] (Non Refundable)". Will this allow me to see real time stock data? I'd be trading on a different platform and just using Sierra for charting. Thanks for your help.
[2021-08-17 13:54:36]
John - SC Support - Posts: 38259
In order to get the U.S. Stock data, you need to use the Sierra Chart Exchange Data Feed. As you saw, the data feed fee is $25.00 per month, which is prorated based on when you first activate it within the first month (hence only $13.00 right now since we are about half-way through the month). Then there is also the cost of the exchange itself, which is $10.50 for the U.S. Equities.
Follow the instructions at the following link to setup the Sierra Chart Exchange Data Feed:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
