Date/Time: Sun, 20 Sep 2026 18:52:53 +0000
adding Leeloo account
View Count: 867
| [2021-08-17 03:29:19] |
| User921071 - Posts: 4 |
I am signing up with Leeloo and would like to Use SC on that account - Can we make it so I can use both this account and that one as well?
| [2021-08-17 13:52:07] |
| John - SC Support - Posts: 47939 |
We are not sure what you mean by "Can we make it so I can use both this account and that one as well?" You can use a single Sierra Chart account with multiple trading services. You just need to install additional Sierra Chart software in order to have trading done on one installation to one trading account and another installation to trade a different account (in this case, LeeLoo). Refer to the information at the following link for how to install a second Sierra Chart installation (there are no additional charges for having multiple installations on the same computer): Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
