Date/Time: Sat, 12 Sep 2026 11:52:05 +0000
MBO Data related question
View Count: 2422
[2021-08-17 01:21:38]
ejtrader - Posts: 689
SC Team - Noticed an asterisk at one of the levels in MBO data. What does this represent? Is it possible to capture this in ACSIL?
imageSierra_MBO.PNG / V - Attached On 2021-08-17 01:21:25 UTC - Size: 19.85 KB - 890 views
[2021-08-17 13:46:50]
John - SC Support - Posts: 47854
The Asterisk is your order. Refer to the information here:
Market By Order Data: Determining Your Order's Relative Position in the Queue
[2021-08-17 20:15:12]
Thank you SC Team. Does the internal SC order ID and MBO order ID matches for the large orders?
From the doc - "But, the position relative to other large orders is easily determined by looking at the position of your order in relation to the other orders that are displayed in the column." - While iterating through the MBO orders - wanted to know if I could some how be able to get the position ID relative to the other large orders in the queue. In the example above - my position ID was 2 - would it be possible to get this info from ACSIL?
[2021-08-18 13:35:31]
Regarding post #3, we need to look into that.
[2021-08-31 10:20:57]
Using the sc.GetBidMarketLimitOrdersForPrice/sc.GetaskMarketLimitOrdersForPricefunctions, you can access the market orders data (market by order data) which includes the actual exchange order IDs
We will then add to this data structure the exchange order ID:
Automated Trading From an Advanced Custom Study: s_SCTradeOrder Structure Members
[2022-01-12 19:19:59]
SC Team - wondering if the post #5 related change you have mentioned is implemented or still pending.
[2022-03-10 14:33:38]
SC Team - Have a question related to the MBO data.
-- Does MBO data contains the time when the order is made into order book?
-- Is this data provided by CME?
-- If CME provides this data - is this tracked as part of Sierra. From current structure of MBO - it doesn't appear like it is tracked in Sierra - but not sure whether this data is actually provided by CME or not.
[2022-03-10 14:39:54]
No.
Not sure. Simply refer to the CME MDP reference and find out.
It would be very doubtful we would go through the effort to add this though.
[2026-02-26 19:31:12]
User558609 - Posts: 7
Post #5 said you’d add the exchange order ID to s_SCTradeOrder so we can match orders to MBO (GetBidMarketLimitOrdersForPrice OrderID). We’re using TrueExchangeOrderID but it has the service order ID (e.g. 705603), not the MBO exchange ID (e.g. 6873020104233). Is there a member that matches MBO’s OrderID, or could one be added?
Alternatively, is there a different way of calculating the queue position with MBO data?
Thank you
[2026-02-27 06:13:39]
Sierra_Chart Engineering - Posts: 24841
Are you obtaining that in a sub instance of Sierra Chart? Check that variable, in the main instance of Sierra Chart.
[2026-02-28 16:56:05]
Can confirm this worked on the main instance
[2026-03-02 20:59:17]
Due to how order identifiers, are handled in a sub instance, the actual original exchange order ID is not available in the sub instance.
Date Time Of Last Edit: 2026-03-02 20:59:24
