Date/Time: Fri, 28 Feb 2025 10:21:38 +0000
Question on Trading & adjusting the scale on the right-hand side of a chart (no mouse)
View Count: 533
[2021-08-16 22:34:25]
User403752 - Posts: 1
How do I adjust the scale on the right-hand side of a chart if I don't have a mouse? Thank you so much!
Date Time Of Last Edit: 2021-08-17 09:22:51
[2021-08-17 13:17:43]
John - SC Support - Posts: 38259
You can access the Menu options for the Scale, and depending on what you want to do, you have a number of options there. You can also access the Scale window from Chart >> Chart Settings and make adjustments there.
But, in terms of expanding/compressing the scale, there is not an option without a pointer of some kind. The best option would be to use a Constant Range and adjust that range as needed.
The information on Scaling can be found here:
Chart Scale and Scale Adjusting
