Date/Time: Sun, 02 Mar 2025 21:50:07 +0000
Order Allocations to Trade Accounts Confirmations
View Count: 811
[2021-08-16 19:30:57] |
TriStar Trading - Posts: 148 |
I am using Order Allocation between two accounts. I have a window up for each account but am trading only off the one window. Confirmations have been shut off on both windows. I am still getting order confirmations when exiting a trade. Am I missing a setting somewhere? Thanks! P.S. - Just attached dialog of message. Date Time Of Last Edit: 2021-08-16 20:05:12
[2021-08-17 13:44:59] |
Sierra_Chart Engineering - Posts: 18607 |
This confirmation still is displaying for safety reasons. We can see about disabling it.
[2021-09-13 22:03:26] |
I was just checking back on this. Can anything be done to be able to disable this confirmation? I prefer the speed of execution over the safety reasons whatever they may be. Especially on the "Flatten" button. When I use that I want out now, or sooner if I could. :) Thanks!
[2021-09-14 20:44:03] |
We will go over this again, this week.
[2021-09-15 07:39:46] |
In the next release, if you have this option enabled, then there will not be confirmations in this case: Global Trade Settings Windows: Disable Order Confirmations - Global (Global Settings >> Chart Trade Settings >> General >> Confirmations) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-27 12:16:47] |
User76183 - Posts: 69 |
I tried to use order allocation. It works when I placing order, but when I cancel it is only removes from the main account , but on the second account the order remains.How to solve it?
[2021-10-27 12:53:10] |
I've found you must use the Cancel All button on a Trade Window. If you use the "X" on the Orders and Positions line it only cancels in the account you canceled the order in. Hope that helps.
