Date/Time: Tue, 04 Mar 2025 12:32:34 +0000
Rithmic and Denali
View Count: 2321
[2021-08-16 19:11:23]
S-A-77 - Posts: 20
I just wanted to know if it is possible to have a rithmic trading account and also have denali historical data.This is because when I connect the rithmic account to sierra and use the rithmic account for the historical data too,my charts and market profile are not showing much data and no historical data.
Many thanks
[2021-08-16 19:50:11]
John - SC Support - Posts: 38341
Yes, that is a shortcoming of the Rithmic data, in that there is a lack of historical data available. It is not possible to have Rithmic for the real-time data and use Sierra Chart for the historical/backfill data.
You should really just use the Denali Exchange Data Feed for your data, which you can use with Rithmic (or any of the other supported) trading service. Refer to the information for the Denali Exchange Data Feed here:
And refer to the Integration with Trading for how to use the Sierra Chart data feeds with your trading service:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
[2021-08-16 21:10:44]
S-A-77 - Posts: 20
Could this also be done with rithmic paper trading services instead of live accounts?
[2021-08-16 21:29:14]
You can use the Denali Exchange Data Feed with the Rithmic Paper Trading. But, in order to validate your account for the CME Group, you would have to connect to your live Rithmic account at least once a month. Refer to the following:
[2021-12-12 21:16:05]
madness99 - Posts: 35
Hi Support,
What if my Rithmic Paper Trading is from one of the prop firms like LeeLoo, Apex, Earn2trade and Uprofit? I don't have live account from them, I use Rithmic Paper Trading option. Does that mean Denali and Rithmic won't work for me?
J
[2021-12-13 17:11:33]
If you do not have another trading account of your own, then you will not be able to get the CME Group data at the non-professional rates. The connection to the prop firms does not count towards the requirement of the CME Group.
We recommend the following service to allow you to create an account for a relatively small outlay of funds in order to qualify for the CME Group requirement of having a funded account to get the exchanges at the non-professional rates:
Easy Solution to CME Funded Trading Account Requirement
