Date/Time: Fri, 28 Feb 2025 10:09:35 +0000
Problem datafeed
View Count: 398
[2021-08-16 16:12:52] |
KevinVongsouvanh914 - Posts: 5 |
Hi support Please for the second times I have a problem with the data cause I can not see the order limit into the Order book This is the second time less than 30 days >> Thanks to help https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=53785 |
[2021-08-16 18:07:10] |
John - SC Support - Posts: 38259 |
We can not help with data from CQG. You would need to check with your broker to see if there is an issue with the data you are setup to get. In order to have the best experience using Sierra Chart, we recommend using our Denali Exchange Data Feed. Refer to the information here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
