Date/Time: Sat, 01 Mar 2025 01:57:13 +0000
Finding micro treasuries - just added by CME
View Count: 1480
[2021-08-16 15:04:54]
sjwtrader - Posts: 3
Hi Sierra team,
I'm trying to add the newly added micro treasuries (ie: 2yy,30yy etc) to my sierra chart - and can't seem to find them. I went to global setting and did an update, disconnected and reconnected, disabled custom global as recommended in other support answers.
Any advice so I can add these to my sierra symbols?
I use Amp, with Denali data, and CQG for execution.
Thanks in advance.
[2021-08-16 17:12:03]
User90125 - Posts: 715
+1
[2021-08-16 21:33:55]
We need to set these up.
[2021-08-23 15:32:25]
It's been over a week since introduction of these new Micro Treasury Yield futures by the CME Group.
Could you advise on the status?
Thanks.
[2021-08-25 11:21:12]
KXRCap - Posts: 64
Dear SC -
The CME 10y Yld Contracts are now averaging 10,000+ contracts a day. There should be no reason we cannot access these. Or since we all pay the CME Exchange Data Fees it should not be the conduit service that says we as customers can or cannot see quotes. I can understand 'vaguely' that a FCM may have minimum volume standards to allow for trading in an instrument, but if you pay exchange fees you should be able to see all the quotes.
Please.
[2021-08-26 16:53:10]
These new contracts have been added for :
SC Data-All Services
SC Order Routing
They have not yet been set up for other services.
[2021-08-27 17:08:14]
User918738 - Posts: 31
Do i need to restart my sierra charts to see the new trading product? I don't see it on my platform.
Using Denali data, is the symbol 10YQ21 for the August Micro 10 year yield future.
Date Time Of Last Edit: 2021-08-27 17:08:55
[2021-08-28 14:10:23]
John - SC Support - Posts: 38292
Your Current Selected Service is set to CQG. We have not entered the symbol information for CQG yet.
To find the symbol that would be used for CQG, refer to this page:
https://www.cqg.com/partners/exchanges/tradable-symbols
[2021-08-29 20:14:40]
These contracts have now been added for CQG.
[2021-08-30 14:00:30]
KXRCap - Posts: 64
Dear SC -
Thanks for adding the Treasury Yld contracts. in the CQG symbols the need to have their decimal adjusted.
Currently quoting 1300.000 should be 1.300
Symbol Example:
F.US.Z10YQ21
Thanks, KXR
[2021-08-30 15:22:01]
We are checking on this now.
[2021-08-30 15:34:39]
This is now corrected for CQG.
After the Symbol Settings are updated, you need to do this for each symbol:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
[2021-08-30 15:34:59]
SpearChucker - Posts: 104
I see the symbols added to Denali, but no data. When can we expect this to be completed?
[2021-08-30 15:54:42]
This has already been completed, last week.
Here is an example chart:
http://www.sierrachart.com/image.php?Image=1630338876394.png
[2021-08-30 17:24:47]
That's not what I see. I have no data except for a few trades in 10y and 30y. And, from what I understand from the CME, these products represent the yields on the Notes/Bonds. So, on the chart you posted and what I show on my DOM the price is off by a factor of 1000.
Date Time Of Last Edit: 2021-08-30 17:26:18
imageYield.jpg / V - Attached On 2021-08-30 17:24:37 UTC - Size: 729.19 KB - 195 views
[2021-08-30 17:27:23]
Use the August contract. Not September.
And yes we do need to make an adjustment to the price multiplier. We will do that.
Date Time Of Last Edit: 2021-08-30 17:27:54
[2021-09-08 18:03:15]
HerculesT41 - Posts: 12
Few things
1) not able to get data past 31Aug. see image. did rollover enabled and Delete & redownload.. but no success
2) symbol is available in internal sim but not in simulated server side futures simulation trading. did updated form server under global symbol setting of my server simulated futures instance of SC but nothing.
imageCapture.PNG / V - Attached On 2021-09-08 18:03:11 UTC - Size: 99.63 KB - 173 views
[2021-09-09 14:28:41]
1. The symbol you are showing in the chart is the Q (August) contract. You need to rollover and select the U (September) contract.
2. We will have to look at adding these for the Simulated Futures Trading Service.
[2021-09-20 14:05:54]
These symbols have been added to the Simulated Futures Trading service.
Date Time Of Last Edit: 2021-09-20 14:06:13
