Date/Time: Fri, 28 Feb 2025 10:39:08 +0000
Cumulative Delta issues
View Count: 398
[2021-08-16 14:42:21] |
AdrianB - Posts: 3 |
Hello, most of my cumulative volume delta is not displaying correctly (attached picture). I have tried reloading the data, indicator, charts, platform, etc. and cant figure it out. This is a CQG connection I just activated yesterday via AMP. The screenshot attached is crude oil, but its happening in every instrument.
Date Time Of Last Edit: 2021-08-16 15:09:25
[2021-08-16 17:47:45] |
John - SC Support - Posts: 38259 |
The only thing we can tell you is that in order to not have issues with the data use our Denali Exchange Data Feed. Refer to the information here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-16 18:00:32] |
You must use the Denali Exchange Data Feed when using CQG. CQG does not have acceptable data for Sierra Chart.
