Date/Time: Fri, 28 Feb 2025 10:00:47 +0000
Questions on Bookmap and Denali
View Count: 1271
[2021-08-16 06:37:15] |
maxm1987 - Posts: 119 |
Hello there, I like to use Bookmap. I read that using Bookmap is not possible with the Denali Data Feed and therefore I have some questions: 1. Is it correct that Denali does not work with Bookmap or would I need to inquire directly at Bookmap? 2. How would be the process to change from Denali to Rithmic? I currently use Interactive Brokers with Sierrca Chart and the Denali Data Feed Thanks. |
[2021-08-16 16:18:50] |
AKR - Posts: 524 |
Question in addition. I guess I can not use Denali with BM, but in case I can use AMP CQG credentials, can I then cancel exchanges with Sierra and take with AMP and still use Denali?
[2021-08-16 18:17:11] |
John - SC Support - Posts: 38259 |
1. The Sierra Chart data feeds only work with Sierra Chart. Therefore, the Denali Exchange Data Feed does not work with Bookmap. 2. If you want to use Rithmic, then you would need to change brokers, as Interactive Brokers uses their own interface to the exchange. If you are asking to use Interactive Brokers data, then this is possible, but we really do not recommend it. 3. We do not understand your question. You mention cancelling the exchanges, which would mean that you would not be using the Denali Exchange Data Feed. As noted in #2, it is possible to get the data from CQG and use it in Sierra Chart, but we recommend using the Denali Exchange Data Feed for your Sierra Chart and if you need other data for Bookmap, then getting that separately. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
