Date/Time: Fri, 28 Feb 2025 10:18:35 +0000
Value Area and Outline not changing color of Value Area volume bars
View Count: 747
[2021-08-15 19:20:50]
FigJam - Posts: 6
Hi, I have gone through the documentation and have (I believe) enabled this correctly, however I am unable to have the Value Area a different color than the rest of the Volume Profile. Interestingly enough, when I enable the "Extend Value Area" settings, the second color DOES show up on the VAH and VAL lines, but not the applicable volume bars. I have attached a screenshot. Thank you for your assistance.
imageScreenshot 2021-08-15 151602.png / V - Attached On 2021-08-15 19:20:34 UTC - Size: 187.24 KB - 223 views
[2021-08-16 16:38:04]
John - SC Support - Posts: 38259
What are the colors set to for the Value Area and Outline (SG9) Subgraph? Are these the same colors as the Volume Bars Outline and Fill Color (SG8). If so, then you need to change one of them so you can see the Value Area.
Date Time Of Last Edit: 2021-08-16 16:38:40
