Date/Time: Fri, 28 Feb 2025 09:01:09 +0000
SC Support - sc.UseTool() - 1) Calc Based On 2) Midline
View Count: 544
[2021-08-15 09:43:10] |
Ackin - Posts: 1865 |
1) "Calc Based On" Please consider adding a parameter for a change/set of this item also to be available through ACSIL. Thank you note This requirement applies to Using Tools with sc.UseTool() via ACSIL (no switching values in the form when drawing the tool manually) s_UseTool::CalcBasedOn Date Time Of Last Edit: 2021-08-15 10:52:29
[2021-08-15 10:55:28] |
2) "Midline on/off" Tool.DrawMidline Please consider adding a parameter for a change/set of this item also to be available through ACSIL for "DRAWING_RAFF_REGRESSION_CHANNEL" and "DRAWING_LINEAR_REGRESSION". Thank you |
[2021-08-18 08:52:24] |
Text above: Is it possible to add to the list of required functionalities in the future? Thank you
[2021-08-18 14:17:25] |
John - SC Support - Posts: 38259 |
Yes, we have these added to our list. We just do not know when we would be able to get to them.
