Date/Time: Fri, 28 Feb 2025 09:19:16 +0000
Large Volume Trade Indicator
View Count: 991
[2021-08-15 00:15:57]
User736044 - Posts: 51
I would like to place on the right side of the candle to display bids only and on the left side ask only. Or to be able to pick the distance between bid and ask circles to be able to place them on both sides of the candle. I tried center of the bar but it is not really center the bid side is dead center and the ask side is on the right of the bar, if i choose left side ask is center and bid is on the left side.
If I choose total is dead center but I want to see based on diagonal.
Thank You!
[2021-08-16 15:51:09]
John - SC Support - Posts: 38259
There is not support for what you are asking for in terms of having Bids on one side and Ask on the other side of the bar.
The choice that would probably work best for what you are wanting to do is "Left/Right Candlestick Body", as this will put the numbers off to the side of the bar, but both on the side.
We are tagging this as a Feature Request for the option to have Bid on one side of the bar and Ask on the other.
[2021-08-16 20:57:15]
That would be awesome, it would be great to be able to have the option to that.
Thank You!
[2021-08-17 00:57:10]
KXRCap - Posts: 64
ST Fix ---- Load LVTI twice. Set one to Left and One to Right reduce size and pick what want in each out of the choices.
[2021-08-17 13:24:07]
This is not quite true. You should only have 1 Large Volume Trade Indicator on a chart at a time, otherwise there can be conflicts. If you do put on more than one, you have to ensure that the Volume Threshold is set to exactly the same value in all the studies. Otherwise, bad things are going to happen (hence the reason why we state that you should only use 1 at a time).
[2021-08-17 22:57:40]
I did that, have 2 one each side but it will show both bids and asks and is confusing, I want to see only the bids on 1 side and only the asks on the other. Of course i want them to show the same size, i don't even think you can have 2 with different sizes. I tried even to make the bids or the asks on each side the same color as the background so I will hide one side and be able to clearly see bids on one side and asks on the other but the bubbles will show up as the background color and will cover other indicators. I am looking to have 2 showing the same size on 1 chart and be able to choose bids only or asks only.
Thank You!
