Date/Time: Mon, 25 Nov 2024 22:29:20 +0000
How load SC without loading the "files to load on startup"
View Count: 1165
[2014-03-20 19:07:40]
NRGTrader - Posts: 351
How can I open Sierra Charts WITHOUT loading "files to open on startup" defined in general Settings? I can't load SC because of the data formatting issues on currencies. Because of these issues, several of my chart books won't load - SC times out. Is there a specific file where these "files to load at startup" is defined? Can I edit that file without opening SC? I have global graphics and tools settings that I don't want to lose.
[2014-03-20 19:57:18]
The way to do this is to rename your Sierra Chart Data Files folder. Usually this is the Data subfolder within the Sierra Chart folder. And then you can remove the Files to Open on Start up in General Settings. Once that is done , exit from Sierra Chart and rename the Data Files folder back to the original name.
