Date/Time: Fri, 28 Feb 2025 09:15:39 +0000
Spread P/L wrong
View Count: 536
[2021-08-14 12:00:24]
SpearChucker - Posts: 104
The P/L for this spread - ZCU21-ZCZ21.ZC.FUT_SPREAD.CBOT is wrong on the DOM & Chart. It reads -4.00 and should be -50.00. Tick value for this spread is $12.50. All the other spreads I have open (different than ZC) show the correct value. Thanks.
imageZC Price.jpg / V - Attached On 2021-08-14 11:59:59 UTC - Size: 206.7 KB - 197 views
[2021-08-16 15:36:31]
John - SC Support - Posts: 38259
Please double check your setting for Chart >> Chart Settings >> Advanced Settings 2 >> Currency Value Per Tick on the Trading DOM that you have pulled up. Make sure you are opening the correct settings window by showing the Menu for the Trade DOM first and then selecting Chart >> Chart Settings for that Trade DOM.
[2021-08-16 19:59:43]
For that DOM the Currency Value Per Tick is set equal to 1. I tried to change the value to 12.50, but no change on the DOM. And, when I checked that value again it was back to 1. All other DOM's have the correct tick value.
[2021-08-18 09:22:36]
Therefore, uncheck this setting:
Chart Settings: Auto Set from Data Feed (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
And manually set the Currency Value per Tick and the Price Display Format and Tick Size in the Chart Settings.
Date Time Of Last Edit: 2021-08-18 09:23:00
