Date/Time: Fri, 28 Feb 2025 08:59:31 +0000
Replay with CQG WebAPI server problem
View Count: 488
[2021-08-13 23:02:48]
User783475 - Posts: 12
I've always used replay chart mode with "SC Data all service" server and all worked fine!
Now i changed server in "CQG WebAPI" and the result is that if i try to use the replay chart mode, the chart is updated every minute, while i setted
Global Settings >> General Settings >> Chart Update Interval in Milliseconds >> 500
why do this happen? how can i use replay as i used to do in "SC Data all service"?
in the first image you can see how the time updating is continuous when i use "SC Data all service";
in the second maybe it is not too clear, but there aren't displayed the seconds, cause it updates only for minute periods when i'm using replay with CQG server;
the third image is the view of my general settings and it's the same for the 2 servers.
Date Time Of Last Edit: 2021-08-14 00:28:49
imageserver all data.png / V - Attached On 2021-08-13 22:52:20 UTC - Size: 22.97 KB - 166 views
imageserver cqg.png / V - Attached On 2021-08-13 22:52:28 UTC - Size: 21.68 KB - 147 views
imagegeneral settings.png / V - Attached On 2021-08-13 22:52:36 UTC - Size: 29.34 KB - 153 views
[2021-08-14 10:06:31]
You will need to use the Sierra Chart Historical Data Service for tick by tick data replay:
Or use the Denali Exchange Data Feed to have tick by tick data when using CQG. Full documentation and instructions:
