Date/Time: Fri, 28 Feb 2025 08:57:00 +0000
swing hi swing lo
View Count: 563
[2021-08-13 13:16:09] |
coachted - Posts: 368 |
I am trying to donw load the data from a 1 minute chart with the swing hi and swing low indicator into a spreadsheet can you tell me why the indicator values are not appearing in the data
[2021-08-13 15:32:52] |
Also is there a way to have an alert for when the swing hi swing low places an arrow on the chart?
[2021-08-14 11:04:15] |
So there is no data at all from the swing high and low study on a Spreadsheet Study Sheet? This is what we see: [ID1] Swing High And Low
[ID1.SG1] Swing High [ID1.SG2] Swing Low 0 0 0 0 0 0 0 0 0 4460.22021484375 0 0 0 0 0 4460.9775390625 4462.0224609375 0 0 0 0 4460.9775390625 0 0 0 0 0 0 0 0 0 4460.98486328125 0 0 0 0 0 0 0 0 0 0 4462.0224609375 4461.2275390625 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-14 11:04:26
