Date/Time: Fri, 28 Feb 2025 10:18:28 +0000
messed up Market Depth
View Count: 564
[2021-08-13 09:03:09]
User740709 - Posts: 153
Thank you for your software and datafeed that I use.
However it seems that the latest update messed up with the Market Depth Historical Graph study as it now ignores the Input of "Number of Minutes to Extend Last Known Depth). I have had it set up to 1 and still have it but despite that it shows the depth as if I had set it up to 0 for All. The problem now persists even though I install previous version.
Could you please advice?
Thank you.
Regards,
H.
[2021-08-13 16:15:17]
We will check on this.
[2021-08-13 16:56:37]
Thank you. Just for you to note, the Msg log contains "Out of order timestamps detected."
All the best.
H.
[2021-08-16 14:10:28]
John - SC Support - Posts: 38259
First, you have us confused by your statements. You state that the issue is with the "Number of Minutes to Extend Last Known Depth", but then you refer to entering values of 1 and 0, which do not make any sense. The default for that field is 60 (meaning 60 minutes) and you would have to set the Input above it for Extend Last Known Depth to Yes in order to actually extend the depth bars where there are none.
But, since you are using the Denali Exchange Data Feed, you can get the historical market depth data for up to the last 15 days. As such, you should rarely have to use the option for Extend Last Known Depth. Refer to the information here:
Market Depth Historical Graph: Downloading Of Historical Market Depth Data
