Date/Time: Tue, 04 Mar 2025 03:36:31 +0000
scsf_TemplateFunction1 not found
View Count: 649
[2021-08-12 16:15:13]
BenjFlame - Posts: 335
I used the default file Mystudies.dll to build my own studies, and removed all what I didn't need from this file.
Since then, from time to time, the message log displays:
"Failed to get the function address for scsf_TemplateFunction1 in C:\SierraChart\Data\MyStudies.dll. Error: Windows error code 127: The specified procedure could not be found. | 2021-08-12 12:08:09.913 *
This procedure was never called or included in my charts, still it is called. How to solve this?
[2021-08-12 18:14:41]
John - SC Support - Posts: 38341
Did you start with source code and build the Mystudies.dll, or did you get the Mystudies.dll from somewhere and just using what you need from it?
If you have the source code, then you need to go through and find the information for scsf_TemplateFunction1 and adjust it as necessary.
If you are just using the .dll, then there is nothing you can do, as something in the file is referencing that function. There is no way to "fix it" in this case, except to get the source code and recompile.
[2021-11-21 16:26:06]
Remove this function from the source code file:
If it is in a comment, remove the comment.
Date Time Of Last Edit: 2021-11-21 16:26:40
