Date/Time: Fri, 28 Feb 2025 08:56:17 +0000
My daily ES chart on Sierra only shows a couple days.
View Count: 460
[2021-08-12 16:12:01] |
User671757 - Posts: 2 |
Also, how do I get the stop to automatically go to breakeven after a certain point?
[2021-08-12 18:09:59] |
John - SC Support - Posts: 38259 |
The lack of data would be something you need to ask CQG (or your broker) about. The best solution is to use the Denali Exchange Data Feed. Refer to the information on this page: Denali Exchange Data Feed ----------- To move the stop to breakeven refer to the following: Attached Orders: Move to Breakeven for Stop For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-13 16:36:06] |
You are running an old version of Sierra Chart. You need to update to the current version: Software Download: Fast Update And for the best and complete historical data for Sierra Chart you must use the Denali Exchange Data Feed. Refer to: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-13 16:37:02
