Date/Time: Wed, 05 Mar 2025 19:38:25 +0000
Paid Support/Tool Enhancement
View Count: 617
[2021-08-12 16:07:09] |
User92573 - Posts: 547 |
Dear Sierra Please would you consider making some changes/enhancements to both the Time projection and Time Expansion Tool. At present the Standard, Compress and Extend are fine for presentation of the ratio lines but when using compress or standard it is very difficult to "move" the "ratio lines" vertically to the required position as the: Time End (Time Expansion Tool) Proj. Start (Time Projection Tool) .. anchors are not locked. Ideally on Create, or Adjust, the Anchor/s and Projection Point should be fully extended vertically irrespective of any other show/hide/level settings. This would allow proper placement/adjustment of the final line even when using the standard/compressed and any other show/hide settings are employed. Or the Horizontal Position can be locked so that vertical position can be manually set without losing the anchor positions. As always, I'd be happy to contribute to the cost of the enhancement. Please would you initially confirm the cost and the timeframe. Many thanks |
[2021-08-16 16:06:16] |
We will have to review this later on. It is not something we can get to right now.
[2021-08-17 09:54:24] |
Thank you. Can I ask if Al Slane is still with SC? Many thanks |
[2022-01-19 15:37:36] |
Sierra_Chart Engineering - Posts: 18663 |
No and we cannot comment on that further.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-19 15:37:53
