Date/Time: Tue, 15 Sep 2026 17:29:33 +0000
How to download historical data from IQfeed
View Count: 1727
| [2021-08-12 15:28:22] |
| User945742 - Posts: 12 |
hi I have iqfeed subscription for a month, I want to download historical data for backtesting so that once I don't have subscription I can still continue with SC for Backtesting, how to do that? Please recommend. |
| [2021-08-12 15:40:10] |
| John - SC Support - Posts: 47898 |
You just need to download the data you want, as you would while using Sierra Chart at any time. For instance, if you are wanting Continuous Contract Data for a symbol, then you would open the current symbol and set the chart to be a Continuous Contract Chart and set the number of days for which you want to load the data. Otherwise, if you are wanting data for a specific contract, then you would need to open that contract up and again, set the number days for which you want the data. In general, refer to the following: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad Also refer to the following: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-08-14 07:55:32] |
thanks, how i ensure that data is downloaded and I can now backtest offline? and which format it download the data?
Date Time Of Last Edit: 2021-08-14 07:59:46
| [2021-08-14 10:08:02] |
There is nothing special to do. Once you open a chart and the historical data is downloaded it will remain. Nothing more to do. The easiest thing to do though is to use this service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-14 10:08:24
