Date/Time: Fri, 28 Feb 2025 09:42:31 +0000
[Locked] - Bid and Ask spread
View Count: 900
[2021-08-12 15:21:02] |
Tonkadad - Posts: 235 |
How can I get the Bid and Ask spread on a chart? I know I can do it with a Quote board, but would like the info right on chart, is this possible?
[2021-08-12 15:29:25] |
John - SC Support - Posts: 38259 |
Attached is a Study Collection that will do what you want. You may have to adjust the Value Format of the Study Subgraphs Subtract/Difference for each chart that you use the study collection on. Refer to the following for how to use a Study Collection provided by us: Study Collections: Using a Study Collection Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-12 16:06:29] |
Getting weird behavior, when I switched stocks it still had the spread from previous stock, and now the spread is negative? I have other studies on chart, should B&A Spread be first in line?
[2021-08-12 16:18:12] |
You will have to make sure that you have all the references correct in the different studies that make up the Study Collection so that they are referencing the right pieces of information. You just have to make sure that the "Bid and Ask Prices" is before the "Study Subgraphs Subtract/Difference" which is before the "Text Display for Study". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
