Date/Time: Fri, 28 Feb 2025 09:21:11 +0000
trailing stop loss
View Count: 462
[2021-08-12 15:06:25]
User356540 - Posts: 5
hello,
I'm french and i don't speak english.
Is it possible to have a trailing stop loss based on a moving average automatically in the control panel by checking use attached orders.
example: long order
moving average x periods minus 2 ticks.
Thank you for your reply
[2021-08-12 15:16:08]
John - SC Support - Posts: 38259
You can write your posts in French and we will use Google Translate to translate them if that is easier for you.
To what you are requesting, you would add an attached stop to the trade and then use the Trade Management by Study study to adjust the stop. Refer to the information here:
Attached Orders: Study Controlled Targets and Stops
