Date/Time: Fri, 28 Feb 2025 09:17:43 +0000
TPO charts strange behaviour
View Count: 459
[2021-08-12 08:19:54]
User990654 - Posts: 6
I've found kind of a bug in the TPO charts :
When you request TPO study settings under 30mn (for each TPO) AND session times for NYC session only, the chart doesn't split each new TPO at the requested timeframe (1mn for instance) as the new session starts if it is merged with data from the previous session.
Thanks to let me know if this is actually a bug or if I'm wrong anywhere in my settings.
Best regards,
DL.
Date Time Of Last Edit: 2021-08-12 09:11:23
Private File
Private File
Private File
[2021-08-12 14:14:45]
John - SC Support - Posts: 38259
We need to understand the steps you took to get this to occur, as we are not fully understanding. Especially in terms of merging the data. Was the data correct before the merge? Was it only after you merged the profile with the one before it that you got the "strange" start times?
[2021-08-12 16:57:47]
1-Data is correct before the merge
2-As soon as you merge NYC starting session with yesterday NYC session (from 9:30:00 to 16:14:59), the new session data is not correct : it doesn't split at the requested timeframe
3-Thanks !
[2021-08-12 18:17:10]
Please get us a copy of that chart by following these instructions:
