Date/Time: Fri, 28 Feb 2025 09:38:07 +0000
Stop to B/E
View Count: 425
[2021-08-11 21:52:11] |
User377189 - Posts: 203 |
I have attached a screenshot I am trying to save OCO configurations and have created a stop of 30 ticks and target of 90 ticks I am looking to, move my stop automatically to B/E after price has moved 60 ticks and then stop stays at 60 ticks till target is hit or i get stopped out at 60 ticks. As per my understanding under Move to Breakeven for stop i need to: 1) Select Step 1 2) Select Offset in Ticks Triggered 3) BE Level Offset - i guess this would be 60 ticks based on the above mentioned 4) Trigger offset - i am not clear what this is |
[2021-08-11 21:56:34] |
John - SC Support - Posts: 38259 |
Refer to the Instructions for Move to BreakEven here: Attached Orders: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
