Date/Time: Fri, 28 Feb 2025 09:07:37 +0000
Options on ES the DOM changed from 46.50 to 4670.7?
View Count: 460
[2021-08-11 19:48:27] |
Justin Dirico - Posts: 2 |
I traded ES options, I'm new to Sierra, I bought 46.50 and 46.75 on ES 4420 puts expiring in september. Once I got my fill the DOM changed to and moved the decimal over. I'm at a complete loss for whats going on.
[2021-08-12 04:40:53] |
Is this Chart Setting enabled/checked?: Chart Settings: Auto Set from Data Feed (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) (Auto Set from Data feed) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
